1989 Honda CRX Hf Just starting out
Here is my roommates CRX he just bought it's a nice little project with a JDM B16a swap in it... It's all stock for now but plans call for a turbo kit similar to NSXMatt Neukin Manifold and a SC61...Also some body work, and lots of weight reduction
Modified by Robs_B18c at 3:56 PM 4/13/2006
The rust looks like it has caused some serious damage to the passengers rear wheel well. Is it as bad as it looks?? Hopefully you can get all the body damaged worked out. Good Luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nicks_jdmstyle_ef9 »</TD></TR><TR><TD CLASS="quote">The rust looks like it has caused some serious damage to the passengers rear wheel well. Is it as bad as it looks?? Hopefully you can get all the body damaged worked out. Good Luck</TD></TR></TABLE>
Not too bad.. Looks worst then it really is???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXb18Turbo »</TD></TR><TR><TD CLASS="quote">nice startup.
Is it just me or is there a hole on your header?</TD></TR></TABLE>
Yeah there is a hole drilled out for an EGT gauge....It's just a cheap no name header anyways :
monsterbuiltk24
Nov 12, 2018 06:56 AM
crx_ef8
23
Apr 15, 2003 03:59 AM
