Hepl! RPM bouncing up and down
i got a b16a1 bod0 and i recently change it to obd1(wiring harness, p30ecu, gsr dizzy, used 4wired 02 sensor) on my b16a1 but i didn't change my injectors to obd1. b4 the obd1 conversion my car ran fine but now it runs wacky(rpm bouncing from 350rpm to 1200rpm) and anyone help me. do i need to change my injectors to obd1 too? there's no cell code. how can i tell my 02 sensor is bad?
Modified by SuperRacerTypeR at 2:29 AM 1/3/2006
Modified by SuperRacerTypeR at 7:29 AM 1/21/2006
yeah, unplug the IACV wire harness in back of manifold and then set idle. After desired idle is reached plug it back in, turn off car, and take out hazard fuse for 5 seconds to clear cels, then replace fuse and all should be good.
jacoblytle
Engine Management and Tuning
Jun 25, 2014 07:56 AM
fernruffryders
10
Mar 16, 2006 01:03 PM
is the vtec doesn't kick in.
