iceman vs aem cold air for itr
Old Mar 19, 2002 | 08:19 AM
snake01's Avatar
Default iceman vs aem cold air for itr
I was curious if the iceman is any louder then the aem and if so do you lose any performance between the two.
Old Mar 19, 2002 | 08:28 AM
hooptie157's Avatar
Default Re: iceman vs aem cold air for itr (snake01)
hey this is gonna get locked in acouple of seconds, do a search to find more info
The Icebox is much better with mid range torque (which we need). I had the AEM but the sonic boom when VTEC hit definalty get old and the power curve was to choppy for my taste. So I went to the icebox (which I'm waiting for right now). From I've read from posts here the sound is alittle deeper than stock in VTEC but not a big difference. I perfer the quiter sound and te better mid-range the icebox has
[Modified by hooptie157, 5:28 PM 3/19/2002]
Old Mar 19, 2002 | 09:38 AM
JoshRambo's Avatar
Default Re: iceman vs aem cold air for itr (hooptie157)
i also switched from an AEM to the icebox. i like it a lot more.
if you are looking for inn intake I am selling my AEM
https://honda-tech.com/zerothread?id=148023
[Modified by Gravity, 1:38 PM 3/19/2002]
Old Mar 19, 2002 | 09:51 AM
Padawan's Avatar
Darth ModerVader
I believe he's asking about the Iceman CAI compared to the AEM CAI. If so, I don't think many people in this forum have experience with the Iceman, since most CAI users are using either the AEM, Injen, or Comptech. I don't see any reason to choose the Iceman over the AEM or Injen though, especially with the current pricing available for the AEM.
As for loudness, I would assume that the plastic used for the Iceman would lessen the noise slightly, though this might be offset by the fact that the Iceman opens to a larger diameter at the filter. HTH.
Old Mar 19, 2002 | 09:53 AM
joy-Ride's Avatar
Default Re: iceman vs aem cold air for itr (SpecR0123)
My friends Iceman get hot as shiet under the hood...This may be a drawback from the material the use...
Old Mar 19, 2002 | 09:54 AM
Digital-R's Avatar
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1812481854
Old Mar 19, 2002 | 11:11 AM
TypeR0149's Avatar
Default Re: iceman vs aem cold air for itr (Digital-R)
alot of people I know use the ICEMAN, i have always wondered why others dont, alot of people get custom size piping made.
Old Mar 19, 2002 | 11:46 AM
Junglist's Avatar
Default Re: iceman vs aem cold air for itr (Lunchbox)
The people over at importbuilders swear by the iceman. I guess the materials used keep the air much colder than the competion. And , correct me if I'm wrong, every 10 degrees cooler gives you 1whp.
I, however, like the Icebox. It is the same setup as stock, but the short ram part isn't made of plastic. I figure that the boys over at Honda really know what they are doing, and the Icebox is just an improvment in heat conditioning.
Also, if you want to save $360, you can put a tube of dryer duct over your stock plastic short ram. This will cut down heat just the same as any of systems avalible with just one problem, it looks jet-O.
Anyway, I hope that helps somebody.
peace,
b
[Modified by Junglist, 12:47 PM 3/19/2002]
Old Mar 19, 2002 | 12:52 PM
redteg1's Avatar
Default Re: iceman vs aem cold air for itr (Gravity)
why do u like the icebox much more?
Old Mar 19, 2002 | 12:53 PM
redteg1's Avatar
Old Mar 19, 2002 | 12:58 PM
protocol_droid's Avatar
Default Re: iceman vs aem cold air for itr (redteg1)
My two bits... I've got a 95 GSR with the iceman CAI. I lost a lot of low end, very noticeable at first and I was a bit disappointed because of it. Up top it did pull stronger from 5K on up and I thought this was a good enough trade off for me to keep it. I have no experience with the AEM.
Old Mar 19, 2002 | 01:01 PM
GokuSSJ4's Avatar
Iceman dyno proven.
Old Mar 19, 2002 | 01:11 PM
t's Avatar
t
Default Re: iceman vs aem cold air for itr (Spoon1)
Iceman dyno proven.
Old Mar 19, 2002 | 01:16 PM
garagespecial
Guest
Posts: n/a
Default Re: iceman vs aem cold air for itr (t)
looks nicer in black too
Iboot
Feb 7, 2007 08:56 AM
ernald711
Mar 7, 2004 09:23 AM
Cottonwoodz
Aug 9, 2002 03:52 PM
the bUCk
May 9, 2002 05:16 AM
Crossett
Dec 5, 2001 04:26 PM
