ALUMALOY ? to repair a TINY, hairline crack near the oil pressure sensor hole ?
Old Jan 2, 2006 | 04:11 PM
93CharcoalHatch's Avatar
Default ALUMALOY ? to repair a TINY, hairline crack near the oil pressure sensor hole ?
it is a TINY, hairline crack but does leak oil prety bad.. i will probably get flamed for asking this but what do you guys think?
Old Jan 2, 2006 | 04:23 PM
shortyz21's Avatar
Default Re: ALUMALOY ? to repair a TINY, hairline crack near the oil pressure sensor hole ? (93CharcoalHatch
if its just a small crack JB weld it if yor just looking to seal it up.../
Old Jan 2, 2006 | 06:03 PM
Niles's Avatar
The problem with cracks is that they can grow very quickly. Any idea what caused the crack? Over tightened bolt? If you do use JB weld or another adhesive, keep an eye on it for a while to make sure it isn't still growing due to some source of stress...
Old Jan 2, 2006 | 06:47 PM
Formula Racing's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Niles &raquo;</TD></TR><TR><TD CLASS="quote">The problem with cracks is that they can grow very quickly. Any idea what caused the crack? Over tightened bolt? If you do use JB weld or another adhesive, keep an eye on it for a while to make sure it isn't still growing due to some source of stress...</TD></TR></TABLE>
I would suggest drilling a hole @ the end of the crack, then cleaning the hell out of the block and follow that with JB weld allowing it to set for 2x its recommended time..
If its not clean, it wont stick.
That Alumaloy is crap.. I have tried it before..
Old Jan 2, 2006 | 08:22 PM
beepy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Formula Racing &raquo;</TD></TR><TR><TD CLASS="quote">
That Alumaloy is crap.. I have tried it before.. </TD></TR></TABLE>
Werd. For $10 I thought it might be worth it, I could repair a hole I punched in an aluminum wheel so I could use the set for Victoracers.... No dice. Even using MAPP gas I couldn't get anything thicker than an aluminum can to "weld" using the stuff. The stuff just melted, stuck to the aluminum, and peeled off with any force.
Old Jan 3, 2006 | 07:24 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shortyz21 &raquo;</TD></TR><TR><TD CLASS="quote">if its just a small crack JB weld it if yor just looking to seal it up.../</TD></TR></TABLE>
JB weld didnt seem to work and i let it sit for 47 hours lol it recommends 15 hours
Old Jan 4, 2006 | 03:23 AM
over tightened oil pressure sensor
Old Jan 4, 2006 | 07:42 AM
is there any quick ways to removing JB weld ???
Old Jan 4, 2006 | 07:10 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93CharcoalHatch &raquo;</TD></TR><TR><TD CLASS="quote">is there any quick ways to removing JB weld ??? </TD></TR></TABLE>
Old Jan 5, 2006 | 09:03 AM
Old Jan 6, 2006 | 08:12 AM
Old Jan 7, 2006 | 08:37 AM
shortyz21's Avatar
u can prolly burn it out..
Old Jan 7, 2006 | 03:02 PM
snootworks's Avatar
JB Weld usually comes off pretty easy if you burn it with a propane torch.
Old Jan 7, 2006 | 07:59 PM
Default Re: (snootworks)
cool thanks alot
rice a roni
Mar 28, 2007 04:55 AM
93CharcoalHatch
24
Jan 9, 2006 04:19 AM
TURBO DC2
May 26, 2005 01:00 PM
KeithGSR
22
Apr 3, 2005 05:42 PM
MeanGreenEG9
Jan 20, 2003 11:04 AM
