problem with crx. wont start.
Old Jan 2, 2006 | 10:26 AM
b18a1ef9's Avatar
Default problem with crx. wont start.
hey guys whats up, my friend was driving his stock 90 dx and it was raining, so we turn the corner and he gets a little wheel spin when he gets out of first gear, right after that his car just shut off. we pull over and try to turn the car back on and it cranks but wont start, it leaves a pretty loud backfire. so i check the timing belt to see if it skipped teeth and it didnt, then since it backfired i figured its gotta be something with the distributor so we pull out the cap and the rotor screw fell off. well we put that back on and it still backfires when he's tryin to start it. any flames or help will be appreciated thanks.
Modified by b18a1ef9 at 12:14 PM 1/2/2006
Old Jan 2, 2006 | 10:35 AM
SD_Lurker's Avatar
HT White Ops
Default Re: problem with crx. wont start. (b18a1ef9)
did you friend have a cold air intake on his car??? if so he could have sucked up some water and that can cause the same symtoms. good luck
Old Jan 2, 2006 | 11:02 AM
b18a1ef9's Avatar
no cold air, this car is bone stock. thanks for the help though.
Old Jan 2, 2006 | 11:28 AM
b18a1ef9's Avatar
Old Jan 2, 2006 | 11:50 AM
b18a1ef9's Avatar
Old Jan 2, 2006 | 12:50 PM
b18a1ef9's Avatar
anyone else
munchlax
Aug 27, 2011 12:08 AM
extracrunchie
May 29, 2007 09:57 AM
bob006
Jan 9, 2006 02:47 PM
bumthology
Apr 2, 2004 11:30 PM
