tranny question
Old Jan 2, 2006 | 08:28 AM
90civSi's Avatar
Default tranny question
i have a b16 and the y1 (lsd) tranny, for some reason there is fluid coming from that top slotted vent, tranny fluid i believe. could it be cause the axle seals are bad or could it be because when i put the tranny fluid in the VSS i didnt take off the front cap to let the fluid get in better? thanks
Old Jan 2, 2006 | 08:42 AM
crexer's Avatar
Default Re: tranny question (90civSi)
you could always try draining it and adding fluid through the correct spot. How much tranny fluid did you use?
Old Jan 2, 2006 | 10:52 AM
ICeDoUt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90civSi &raquo;</TD></TR><TR><TD CLASS="quote">i have a b16 and the y1 (lsd) tranny, for some reason there is fluid coming from that top slotted vent, tranny fluid i believe. could it be cause the axle seals are bad or could it be because when i put the tranny fluid in the VSS i didnt take off the front cap to let the fluid get in better? thanks</TD></TR></TABLE>
when u say tha front cap, i am guessing you mean the correct fill hole.
Well that is removed in order to see when you have enough tranny fluid in there(if filling through vss).
I hope u didn't fill all the way to the top of the vss. If u did, just take the fill bolt out and let the excess drain out.....
Old Jan 2, 2006 | 12:57 PM
90civSi's Avatar
Default Re: tranny question (crexer)
well i put in 2 quarts
Old Jan 2, 2006 | 12:58 PM
90civSi's Avatar
im just hoping this will work so i dont have to pull the tranny off :/
B16EJ
16
Feb 19, 2011 12:48 PM
em12nv
Feb 9, 2008 01:49 PM
TypeRuz
Oct 28, 2003 04:58 PM
