88 DA parts car. What parts?
Old Jan 2, 2006 | 06:44 AM
EFdohcZC's Avatar
Default 88 DA parts car. What parts?
I just obtained an 88 teg LS in a trade, it's wrecked so driving it is out of the question. What parts can I swap onto my EF?
Will these rear discs work? Front? Swaybars? Seats? D16A1 w/ custom front mount?
I have searched and I do know most of the swap parts are from 90-93 tegs.
Any Help is Appreciated!!!
Modified by EFdohcZC at 8:07 AM 1/2/2006
Old Jan 2, 2006 | 07:56 AM
beyondspexj's Avatar
just bout none and a DA is 90-93. maybe the seats if you really want them and make ur own brackets but other than that, anything else might not work. i could be wrong. and the motor would be a waste of time since you need to fab up motor mounts when you can get a 88-95 black top zc motor ( looks the same but valve cover is black ) that has more power and bolts strait into your ef
Old Jan 2, 2006 | 08:32 AM
RacerBoy's Avatar
Default Re: 88 DA parts car. What parts? (EFdohcZC)
None of the parts will swap onto your EF.
And btw, DA integras are from 1990-1993.
Trash the car...unless you have an 85-87 Civic/crx SI.
Old Jan 2, 2006 | 08:58 AM
Old_Honda's Avatar
Default Re: 88 DA parts car. What parts? (RacerBoy)
Actually 86-89 coupe=DA3 and 4dr=DA1, so it's still a DA . That being said, I don't think there's much of anything you can use from it. They have a really odd suspension setup, and I doubt the brakes are bigger than an EF's.
Old Jan 2, 2006 | 09:58 AM
mrsuburban's Avatar
Default Re: 88 DA parts car. What parts? (OldGSR)
id quickly buy a 1st gen crx and theeen you can really have fun with it....other than that no..pretty much nothing..
Old Jan 2, 2006 | 01:46 PM
EFdohcZC's Avatar
Default Re: 88 DA parts car. What parts? (mrsuburban)
Thanks guys, that's exactly what I thought!
Thanks Again,
Kenneth
Old Jan 2, 2006 | 02:19 PM
HiProfile's Avatar
Even the motor/tranny isn't an easy drop-in. The rear is a live axle (solid), and the rear discs are intergrated with the hubs. Even autozone wants over $180 for each rear disc.
The 86-89's are only good as daily drivers if the heater works for winter, or the AC/subroof works for summer. I enjoyed my 88 LS, besides the auto tranny.
Old Jan 3, 2006 | 07:44 AM
chaos32506's Avatar
if you chose to junk or part out pm me, I'd get some parts.
KillerHippy
Mar 3, 2013 05:48 AM
tcjdm26
Oct 9, 2011 11:24 AM
freitasfamily09
Northern California
Aug 4, 2009 11:18 PM
dropNdestroyEF
Feb 24, 2007 10:03 AM
