header for ZC. what other models will fit?
Old Jan 2, 2006 | 06:07 AM
fujiwara takumi's Avatar
Default header for ZC. what other models will fit?
is it basically any 1.6L header that will fit? im looking for dirt cheap. i also still have the stock exhaust from there back, will an aftermarket header made for a zc mate to what i have OK? id assume so otherwise im just going to drop the cat back and throw it in the back of the garage.
Old Jan 2, 2006 | 06:12 AM
eg2sol's Avatar
Default Re: header for ZC. what other models will fit? (fujiwara takumi)
I'm going to say any d-series header will fit. Someone correct me if im wrong.
Old Jan 2, 2006 | 06:21 AM
Padawan's Avatar
Darth ModerVader
A D-series header will bolt on, but the ports will not be perfectly aligned. You can grind the header flange so the ports line up more closely, or if you are less concerned with performance, you can simply leave it the way it is.
galbal
14
Feb 15, 2010 07:20 AM
gsrpedro
Jan 13, 2007 03:21 PM
hondacivic4g
May 12, 2005 10:59 PM
B18C5-EH2
11
Feb 17, 2005 04:35 PM
jayjay
11
Feb 17, 2004 01:22 PM
