Tachometer problems
Old Jan 1, 2006 | 08:35 PM
GReddy212's Avatar
Default Tachometer problems
I have a 92 ex 5spd. For the past couple of days my tach. has not worked at all, it would remain at zero at all times. One night i noticed it jump a few times but then fell back to zero, the next morning i started my car to go to work and the tach. worked fine, as i drove to work it started jumping around and finally fell to zero and for the past two days have not moved. What do you think?
Old Feb 1, 2006 | 10:27 PM
SiDeRaQ's Avatar
Default Re: Tachometer problems (GReddy212)
mines aint working either but when i start my car it moves a lil bit? wat can be the problem. i checked the plugs to the cluster and the dizzy
Old Feb 2, 2006 | 12:22 AM
YeuEmMaiMai's Avatar
either the tach has quit (bad) or it isn't getting a signal from the ignition.
Old Feb 2, 2006 | 07:29 AM
flight50's Avatar
Default Re: Tachometer problems (YeuEmMaiMai)
once my tach completely died on me but it was because my alternator went out. luckily i was about 2 minutes away from the shop that i was taking my car to get looked at.
90si-rex
Apr 8, 2015 10:48 PM
Garry_90Civic
Aug 5, 2014 10:26 PM
blacksheep
Feb 10, 2003 09:53 PM
