JDM B16A3???
Old Jan 1, 2006 | 04:57 PM
redasphalt's Avatar
Default JDM B16A3???
Hey I searched but didn't find what I was looking for.... so here goes....
I recently bought a obd1 XSI swap from a local shop here for $1500... It came with the rare obd1 PR3 ecu, it came with a NO GRIND YS1 tranny (no lsd ), it also came with a B16A3 with 1XXXX on the block... also, the block has a 92 on it... I was told B16A3 were only USDM del sols 94 and up...
On a side note, when the shop recieved the swap, it came with XSI axles, XSI linkage and they told me the tranny and engine were never separated...
Anyways, heres my question: Did any JDM motors come with a B16A3 designation??? Anything would be helpful... Again, i searched but there are 300+ results
my ecu says its from a DA6 too
Old Jan 1, 2006 | 05:02 PM
civic889802's Avatar
thats a usdm i belive the del sol is b16a3 or a 2000 si iam not so shure
i have the wrong tranny for my car my speedometer dont work cus i cant plug the wire that goes in the tranny the tranny i have is a bigger hole the one i need is with a small hole
Old Jan 1, 2006 | 05:26 PM
redasphalt's Avatar
Default Re: (civic889802)
thats what i thought too... i hope that maybe b16a3 were available in XSI's...otherwise i still got a strong super duper USDM wee16.... vrooooommbaaaaaaaaahhhhhhhhhh!!!
Old Jan 1, 2006 | 07:54 PM
xsi is jdm only they dint make the xsi in us lol
Old Jan 2, 2006 | 12:45 AM
ScorpioMk's Avatar
dont jdm motors only say b16a or b18c, they have no # at the end like usdm motors would for example b16a3 or b18c5.
Marcus
Old Jan 2, 2006 | 12:55 AM
payneth's Avatar
Default Re: (ScorpioMk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScorpioMk &raquo;</TD></TR><TR><TD CLASS="quote">dont jdm motors only say b16a or b18c, they have no # at the end like usdm motors would for example b16a3 or b18c5.
Marcus</TD></TR></TABLE>
Thats what i thought too
Old Jan 2, 2006 | 01:50 AM
SiR Inspired ED7's Avatar
Default Re: JDM B16A3??? (redasphalt)
jdm motor have
b16,b18c h22a, like that
usdm motors have b16a1/2/3, b18c1/b18c5/
u get the point.
Old Jan 2, 2006 | 05:42 AM
skiracer8148's Avatar
yeh jdm motors are 4 digits b16a,while usdm b16a3-5 digits
Old Jan 2, 2006 | 08:11 AM
Targa250R's Avatar
be professional
B16A3 = USDM '94-95 del Sol VTEC
Old Jan 2, 2006 | 09:26 AM
superbeastcrx's Avatar
JDM MOTORS DONT HAVE A NUMBER AFTER THE LETTER, SO IF YORS HAS A 3 IT'S NOT JDM!
Old Jan 2, 2006 | 11:48 AM
what if is a b16a1 is that jdm
Old Jan 2, 2006 | 11:51 AM
redasphalt's Avatar
Default Re: JDM B16A3??? (superbeastcrx)
i have a p30 intake manifold... it says pr3 (also has a 92 stamp) on the block by the exhaust manifold, but it has a b16a3 stamp by where it mates to the tranny.... it looks like my motor was pieced together
did the 94-95 del sols have p30 designations?
Old Jan 2, 2006 | 11:57 AM
TurboEM1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by superbeastcrx &raquo;</TD></TR><TR><TD CLASS="quote">
JDM MOTORS DONT HAVE A NUMBER AFTER THE LETTER, SO IF YORS HAS A 3 IT'S NOT JDM!</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic889802 &raquo;</TD></TR><TR><TD CLASS="quote">what if is a b16a1 is that jdm </TD></TR></TABLE>
no as stated above b16a is jdm b16a1/2/3 ect is usdm
Old Jan 2, 2006 | 12:32 PM
drSquish's Avatar
no b16a3s were jdm. you got jipped for your compression. Well look at it this way, if your going to boost stock then your better off.
Old Jan 2, 2006 | 12:39 PM
Zaakro's Avatar
Default Re: (drSquish)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drSquish &raquo;</TD></TR><TR><TD CLASS="quote">no b16a3s were jdm. you got jipped for your compression. Well look at it this way, if your going to boost stock then your better off.</TD></TR></TABLE>
ummm no as stated earlier JDM engines dont have numbers at the end it will be B16A and thats it
Old Jan 2, 2006 | 12:49 PM
redasphalt's Avatar
Default Re: (Zaakro)
yeah, thats what it looks like... also, now my idle stuck at like 2k rpms... i cleaned the iacv (the thing with the screen), i tightend the FITV (the little wax screw thing) and the vaccum lines look fine... I see that they changed the intake manifold to a P30 (obd1) when they pieced my engine together and Im thinking maybe its the im gasket or tb gasket that is leaking and causing high idle But first, i have to fix the busted heater hose and bleed the coolant... maybe if there was air bubbles in the lines it would cause a high idle??? Does air in the lines cause a bouncing erratic idle or a steady high idle like i have???
Old Jan 2, 2006 | 03:19 PM
Crx Jimmy's Avatar
you are all wrong it is EDM, european motors have #'s after b16a unlike their jdm counterparts but retain jdm internals and are not the same as us spec motors. it is definitely from a 92 integra and not a del sol because as stated it is a 1 million series motor not a 3 million series motor which came with hydro tranny's. only cable motors came with the 1 million series #'s. you didnt get jipped its the same compression and everything as the jdm motor.- maybe ask seti20 he is from across the pond i believe
Old Jan 2, 2006 | 03:45 PM
c.dub's Avatar
Default Re: JDM B16A3??? (Crx Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">you are all wrong it is EDM, european motors have #'s after b16a unlike their jdm counterparts but retain jdm internals and are not the same as us spec motors. it is definitely from a 92 integra and not a del sol because as stated it is a 1 million series motor not a 3 million series motor which came with hydro tranny's. only cable motors came with the 1 million series #'s. you didnt get jipped its the same compression and everything as the jdm motor.- maybe ask seti20 he is from across the pond i believe </TD></TR></TABLE>
Beat me to it Euro cars had a fifth digit after them, like B16A3. So your motor could be a European model or an American model. If it came with XSi stuff, then it's probably Euro. And yes, ask seti20, he's a Euro
Old Jan 2, 2006 | 05:23 PM
VtecSyndrome's Avatar
Default Re: (redasphalt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redasphalt &raquo;</TD></TR><TR><TD CLASS="quote">
But first, i have to fix the busted heater hose and bleed the coolant... maybe if there was air bubbles in the lines it would cause a high idle??? Does air in the lines cause a bouncing erratic idle or a steady high idle like i have???</TD></TR></TABLE>
Yes an a bubble in your coolant will cause an irradic idle so bleed your coolant system to eliminate that from the possibilities
Old Jan 2, 2006 | 05:37 PM
SETI20's Avatar
holy ******* ****. Talk about misinformation.
I'm not even gonna bother. This topic went to **** after the first few posts.
Old Jan 2, 2006 | 06:01 PM
speed_racer012's Avatar
Default Re: (SETI20)
No **** dude! I just got a headache reading all that
Old Jan 2, 2006 | 07:59 PM
crxnj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboEM1 &raquo;</TD></TR><TR><TD CLASS="quote">
no as stated above b16a is jdm b16a1/2/3 ect is usdm</TD></TR></TABLE>
No,the b16a1 is from edm cars..We never got a b16a1 in USA..
If it truly has "b16a1" on the block then it is from a edm car.
Old Jan 2, 2006 | 10:21 PM
Custom Rex's Avatar
Default Re: (Mr.speaker)
i'm not to sure about this JDM not including numbers at the end, i have seen JDM motors with B16a1, B16a2 from japan, anyone have any more input?
Old Jan 2, 2006 | 10:27 PM
crxnj's Avatar
Default Re: (Custom Rex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Custom Rex &raquo;</TD></TR><TR><TD CLASS="quote">i'm not to sure about this JDM not including numbers at the end, i have seen JDM motors with B16a1, B16a2 from japan, anyone have any more input?</TD></TR></TABLE>
B16a2 is from usdm 99-00 civic SI and canadian 99-00 civic Sir..
B16a1 is from edm cars..But for some reason alot of people refer to the 89-91 jdm sir1 b16a as a b16a1..and they refer to the b16a sir2 as a b16a2..Its annoying..Even hmotorsonline does it and its confusing alot of people..
Old Jan 3, 2006 | 01:44 AM
redasphalt's Avatar
thanks everybody for your responses ... im gonna talk to the shop i got it from and see if they can help me verify what is going on...
i'll post up pics of my swap once i can get to a camera and it stops raining...
