How often do you rotate ur tires???
What up,
I just got some new rubber so i wanna try n keep em as fresh as possible. my car is lowered about 3 inchs BTW! i was thinking like every 3 weeks?!?!
lemme know
lemme know
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGDC2CIVIC »</TD></TR><TR><TD CLASS="quote">i rotate mine every other oil change, so 5500- 6000 miles</TD></TR></TABLE>
+1
+1
I never rotate my tires period. I just know that I replace my front tires more frequently than the back ones.
There really is no need to rotate tires. It just ensures that at the end you have to buy the four tires at one time.
I dont mind replacing two sets of front tires for every set of back tires.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic_in_LA »</TD></TR><TR><TD CLASS="quote">I never rotate my tires period. I just know that I replace my front tires more frequently than the back ones.
I dont mind replacing two sets of front tires for every set of back tires.</TD></TR></TABLE>
I do the same thing lol
This is only partly true. You are also suppose to rotate your tires left/right (unless they are directional) this compensates for any slight differences from one side to the next. The rear ones go straight to the front and the front ones go to the diagonally opposite corner.
If you have dropped your car 3" and don't have a camber kit rotating your tires will do nothing. It will wear down the inside of you tires regardless on what corner of your car they are on.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle »</TD></TR><TR><TD CLASS="quote">i jsut keep the back ones and burn off the front ones.. once the front ones are gone and i get new fronts and put em on the back
Haha, you guys are either on to something, or lazy as ****.
I do mine (front to back because they're directional) every 6-8k.
</TD></TR></TABLE>Haha, you guys are either on to something, or lazy as ****.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton »</TD></TR><TR><TD CLASS="quote">
I do mine (front to back because they're directional) every 6-8k.</TD></TR></TABLE>
well i got Summer and winter tires..
and i barely put 8k mileson my car a year
Yeah really, there is no need to rotate tires.
I had my car since it was new, in 97, and never did I rotate tires. The whole tire rotation thing is a scam and big conspiracy.
Im running on stock tires, they are cheap as **** and not rotating them has no negative impact on them. Like I said, only the front tires get replaced first. Then keep an eye out and eventually the rear ones will go.
Generally, in FWD (and some FWD-based AWD vehicles), rotate them every oil change. FWD really eats up the front tires, and rotating them will actually increase the time between tire purchases. Sure, you'll probably have to buy all 4 at one time, but why buy an extra pair of fronts when they could last until you need all 4 if they're rotated? With RWD vehicles (and most RWD-based 4WD trucks), you can rotate every other oil change (or even less frequently) and be fine. FWD is, IMO, one of the worst design traits to ever hit cars...unfortunately it's so common that finding a RWD car is actually a PITA. It's great that several manufacturers (most notably Chrysler) are going back to a basic RWD layout...damn I hate FWD, I drive it because there's no other choice.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by old man neri »</TD></TR><TR><TD CLASS="quote">This is only partly true. You are also suppose to rotate your tires left/right (unless they are directional) this compensates for any slight differences from one side to the next. The rear ones go straight to the front and the front ones go to the diagonally opposite corner.</TD></TR></TABLE>
That's with older bias-ply tires. Radial tires, directional or not, are supposed to be rotated front-to-back, not crossed. It can cause uneven wear and slipped belts inside the tire, I've seen that happen too many times when people cross-rotate radial tires.
When you guys say "rotate tires" do you mean actually removing the tire and remounting it either in the opposite direction (non-directional tires) or onto another tire on the other side of the car (directional tires)? Or do you mean swapping the front wheels with the rear wheels?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK k kay »</TD></TR><TR><TD CLASS="quote">When you guys say "rotate tires" do you mean actually removing the tire and remounting it either in the opposite direction (non-directional tires) or onto another tire on the other side of the car (directional tires)? Or do you mean swapping the front wheels with the rear wheels?</TD></TR></TABLE>
Just moving the wheels around on the car (usually front-to-back and vise-versa), it has nothing to do with removing the rubber tire from the metal wheel. If you walk into a dealership and ask for a tire rotation, this is what they're gonna do.
