ls/vtec
Old Jan 1, 2006 | 01:13 PM
EGcivicvtec's Avatar
Default ls/vtec
hey guys, i am building an ls/vtec. well im building the bottom end first. i am going with ctr pistons and eagle rods. not sure on the crank yet which is why i am askin for some opinions on which crank to use. i will eventually get my hands on a 200 b16 head and tranny. any help will be helpful. thanks....mike
Old Jan 1, 2006 | 01:45 PM
joey1320's Avatar
Default Re: ls/vtec (EGcivicvtec)
keep the ls crank unles you get an aftermarket one. keep the ls and get oem bearings
Old Jan 1, 2006 | 03:00 PM
DRAMA's Avatar
ls crank, use ls rods. gsr crank, use gsr rods. if you change the stroke, you need to change the rod length to match deck height or your pistons will hit the head.
Old Jan 2, 2006 | 10:52 AM
Default Re: ls/vtec (StReEt TuNeR)
alright knowing that what would be a good setup for my block for a ls/vtec.
Old Jan 2, 2006 | 10:55 AM
Firstoost's Avatar
why change the crank...I'm not sure about ls cranks, but i know d series cranks are rated for 600hp+
Old Jan 2, 2006 | 12:33 PM
Default Re: ls/vtec (Firstoost)
alright using the ls crank, and i want to go with ctr pistons would i have to shorten the rod length?
Old Jan 4, 2006 | 01:58 PM
does anyone know if i would have to shorten the rod length using the ls crank with ctr pistons?
Old Feb 13, 2006 | 09:54 AM
andrew714's Avatar
the only pistons you can use without problems are the b16 pistons. either p30 or pr3. if you use ITR or CTR pistons you will have to shorten the robs by 1mm on both ends. hope that answers your question
GSR_hatch936
Apr 30, 2008 06:48 PM
EM1OwnerSi
Oct 11, 2006 08:20 PM
its WANG yoO
Jan 31, 2003 09:01 AM
