Bridgestone Potenza S-03 pole positions
I am considering ordering some of the above mentioned tires in size 205-50-15, just wanted to here general opinions on the tire and there performance.
195/55's are cheap right now..... $76 I think.
I had placed my order earlier today with Tirerack. I gotta call from them informing me that the 195 / 50 s are smaller by 1/2 from 195 /55. It's their policy to call. Sounds like an awesome tire. I'm still going to buy them
I run 195/50 SO-3's as well and even though they are rated as the same width the SO-3's are significantly wider than the RE010's. Wheel gap is not noticeable in my opinion. These tires grip incredible in the dry and are even better in the wet. Sidewalls are very stiff too for good turn in. I give them
. For all out street tires there is nothing better.
S03's are the best street tires money buys.. I'm on Michelin Pilot Sports right now, and they rock, but i'm replacing them with S03's.. plus Pilots are $$ and i think 16" is the smallest they make.
I say 205-50-15 is the best as you don't alter the gearing and they provide more tire. They need a little more pressure due to the fit on our smallish 15x6 wheels but trust what everyone says you can't go wrong with either size they are the best street tire out now. I love mine I have the 205-50-15s.
Note: If your car isn't lowered, you'll have even more fenderwell gap after you install the 195/50.
my car has bone stock suspension, and I don't think that the fenderwell gap is more noticeable....check the pic above
However, for the stock 15x6 rim, a 195/50 is going to be the best choice as the wide 205/50's will make the car feel sloppy.
uncleben
Jan 18, 2006 08:23 PM
