si to gsr oil cooler conversion
i building a b18c1 block and i will be using a b16a2 head
the car is a 00 civic si. the b16a2 block dont come with oil cooler.
so im using parts form the b16 and intall it into the gsr block.
it seem that the thermostat housing and tube arent the same because the b16 dont use oil cooler.
so im thinking using a T from the hose that goes to the head and also use it for the oil cooler.
i also have the gsr thermostat housing and tube but the tube has a extra hole on it.
i dont know if i should put a plug
white90rexsi
Oct 27, 2006 03:25 AM
Lee_Delso
Apr 25, 2005 09:15 AM
