Ticking/Tapping in the Head
Old Jan 1, 2006 | 09:10 AM
213374U's Avatar
0x5359-0055
Community Builder
Default Ticking/Tapping in the Head
I recently swapped my motor. There is a ticking/tapping coming from somewhere up in the top of the head. Thing that has me stumped is this only happens when I apply gas while the RPM's sit between 2500 and 3000. Could this just be a valve(s) tapping?
Old Jan 1, 2006 | 10:07 AM
P_Adams's Avatar
Default Re: Ticking/Tapping in the Head (Vt4cPwn35)
Exhaust leak in the EGR system?
Leak in the EGR Valve itself?
Leak at EGR Valve Base gasket?
Valve lash adjustment?
Worn Cam Follower pivot shaft?
Exhaust leak at Header Flange?
Just some suggestions
P
Old Jan 1, 2006 | 01:30 PM
213374U's Avatar
0x5359-0055
Community Builder
Default Re: Ticking/Tapping in the Head (P_Adams)
OK, nother quick question. Would any of the above cause an idle similar to a vacuum leak??? I've searched high and low throughout my engine bay and could only find one leak... on the back of the IM.
That reminds me. Can someone give me pictures of where each of the 3 vacuum ports on the rear, driver's side of the IM run to??? I couldn't find the connection for one of them and just blocked it off
Old Jan 1, 2006 | 01:56 PM
P_Adams's Avatar
The EGR Base Gasket could cause not only an Exhaust leak, but a vacuum leak as well.
You could also have an internal vacume leak in the IACV (Idle Air Control Valve) which causes the traditional "idle hunting" complaint that makes it thru here occasionally. If DesertHonda were still contributing here, he'd have the repair proceedure. (but he isn't).
P
Old Jan 1, 2006 | 03:03 PM
213374U's Avatar
0x5359-0055
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P_Adams &raquo;</TD></TR><TR><TD CLASS="quote">The EGR Base Gasket could cause not only an Exhaust leak, but a vacuum leak as well.
P</TD></TR></TABLE>
Yeah.... just when I need him most Anyway, do you know where those 3 lines run to?
Old Jan 1, 2006 | 03:08 PM
BLKFLSH's Avatar
You can find DH on the superhonda website. I think he may also have an alias here.
blk1stgen
Honda CR-V & Element
Jan 18, 2014 10:58 AM
ryosuke
Apr 15, 2013 11:54 AM
SiRCiviC94
Mar 6, 2013 04:08 PM
::MYCORD::
Sep 18, 2002 07:44 PM
