DPFI to MPFI no spark but priming of fuel pump
Old Jan 1, 2006 | 06:59 AM
90jdmcrxdude's Avatar
Default DPFI to MPFI no spark but priming of fuel pump
I did the swap all the wiring is correct. And when I went to start the car all it does is crank over but it doesnt start. I used to get a loud vibration from the relay under the dash, but that stopped. There is a spark every once and a while from cylinder 2 and 4, but nothing in 1 and 3. I changed the distributer but the same thing is happening. Someone help me!!!
Old Jan 2, 2006 | 02:52 PM
91' LS-VTEC's Avatar
Default Re: DPFI to MPFI no spark but priming of fuel pump (90jdmcrxdude)
I'm having the same problem. Even switched out the coil & ignitor. Still nothing.
Old Jan 2, 2006 | 02:59 PM
mattie_96's Avatar
Default Re: DPFI to MPFI no spark but priming of fuel pump (91' LS-VTEC)
are you 110% sure the 2 white wires on the dizzy are not switched...only one way to find out...depin and switch...hopefully its just that which is the problem
Old Jan 2, 2006 | 03:08 PM
green91's Avatar
i had a very similiar problem.. swapped the 2 white wires and it runs like perfect.
Old Jan 2, 2006 | 03:27 PM
EkLanta's Avatar
Default Re: (green91)
wiring check
Old Jan 2, 2006 | 04:59 PM
green91's Avatar
well the problem with checking the wiring is both white wires are identicle.. no distunguishing them. just de-pin and swap them. wont hurt anything if thats not the problem.
Old Jan 2, 2006 | 05:16 PM
SomeDude56's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by green91 &raquo;</TD></TR><TR><TD CLASS="quote">well the problem with checking the wiring is both white wires are identicle.. no distunguishing them. just de-pin and swap them. wont hurt anything if thats not the problem.</TD></TR></TABLE>
what he said
Old Jan 3, 2006 | 07:07 AM
Default Re: DPFI to MPFI no spark but priming of fuel pump (mattie_96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattie_96 &raquo;</TD></TR><TR><TD CLASS="quote">are you 110% sure the 2 white wires on the dizzy are not switched...only one way to find out...depin and switch...hopefully its just that which is the problem</TD></TR></TABLE>
2? theres 4 white wires & 3 orange wires on one plug. Then 1 black & 1 blue on the other plug. What 2 white wires?
Old Jan 4, 2006 | 07:42 AM
Old Jan 4, 2006 | 02:41 PM
Yeah I went out that night after I posted this and switched the two dizzy wires and now it runs like a champ with a new set of spark plugs I love it
Old Jan 4, 2006 | 03:01 PM
green91's Avatar
congrats on completeling the most worthwhile and easy conversion!
Old Jan 4, 2006 | 05:45 PM
Witch 2 white wires?
Old Jan 4, 2006 | 06:24 PM
Heres a picture of the wiring for the distributer https://honda-tech.com/zerothread?id=1063804
Old Jan 4, 2006 | 08:09 PM
---------------------white-------------------
blue----------------orange-----orange/blue
blue/yellow--------white-------white/blue
---------------------blank------------------
I'm lost or just retarded, you guys keep saying 2 white wires. these both show only one.
Old Jan 4, 2006 | 10:05 PM
Just tried another dizzy. one of my b16 (obd0) same plugs just diffrent legs. and got no spark. anyone have any ideas?
Old Jan 4, 2006 | 10:16 PM
kennyc's Avatar
New User
tried switching the wires got confused dont understand what 2 white wires
Old Jan 5, 2006 | 06:33 AM
Default Re: (kennyc)
Its the white wire and the tan wire they look the same ones in the center and the others like on the bottom look at the picture.
phatboyzef2
26
Feb 28, 2011 12:44 PM
GuitarPunk015
Jun 25, 2009 03:24 PM
Reaper369
Jul 3, 2007 12:03 PM
cbrracer91586
May 19, 2007 04:31 PM
speedfanatic88
Mar 15, 2004 01:14 PM
