'91 Montana Green GTI turbo 16v.......
Old Dec 31, 2005 | 11:10 PM
turbohf's Avatar
Default '91 Montana Green GTI turbo 16v.......
this GTI made 298hp at the wheels with 17psi on a pump gas tune (dyno chart below). ran a 13.21 @ 115mph on the 16" wheels/tires pictured. this GTI hauls ***!!!
throw some slicks on it and add some race gas at 22psi im pretty sure it will run 11's...
1991 VW Golf GTI
Engine:
2.0L ABA bottom end (130k bottom end, with 2.0 16v oil pump, gears, intermidate shaft, brand new oil pan and windage tray)
1.8L 16v head w/3 angle valve grind (new valve guides, new seals ~1000 miles ago)
ARP head studs
Euro Nation custom intake manifold
VR6 throttle body
Euro Nation custom Stainless Steel turbo manifold
Garrett T3/T04E 60 Trim w/Stage 3 .63 A/R exhaust, V-Band discharge (about 1500miles on it)
TiAL 38mm external wastegate (polished)
Euro Nation 3” down pipe
Euro Nation 2.5” charge pipes (all couplers are heavy duty 4 ply, and use quality T-bolt clamps)
TiAL 50mm blow off valve (black anodized)
JohnnyRaceCar 8” intercooler (Core size: 25 wide X 7.75 tall X 2.75 deep)
Turbo Smart ‘Boost Tee’ (manual boost controller)
VF-Engineering driver motor mount
EIP front motor mount
Kent ABF timing belt
Euro Nation/MSD 8.5mm sparkplug wires (OEM plug ends)
new OEM cap and rotor
new OEM upper radiator hose (75bucks!)
dual fans
new low temp thermostat and swtich (not installed)
ABA serpentine system, with new belt (conitech belt)
new OEM throttle cable
new OEM timing belt tensioner
Transmission:
O2A cable shift transmission swap
Peloquin Limited Slip Differential
EIP Competition stage 1 (6 puck sprung disc, heavy duty pressure plate, EIP says good for 400+whp)
lightened G60 flywheel
brand new OEM speedo cable
new throwout bearing
100mm axles in good condition (no rips, clicks, clunks)
Fuel System:
Megasquirt’n’spark (all new custom wiring harness and connectors)
60lbs Seimen Deka injectors mounted in a Audi TT fuel rail
GM 3 Bar MAP sensor (new, AC Delco)
CIS fuel pump/surge tank/fuel filter
Suspension/Wheels/Brakes:
Weitec Coilovers
16” Konig Traffik (wheels)
Dunlop SP Sport FM901 (1000'ish miles)
10.1” front brakes
8.9” rear disc brakes
22mm Master Cylinder
new parking brake cables
manual steering rack
new inner and outer tie rods
professionally alinged
Exterior:
Montana Green paint
E-Code H4 Hella headlights (OEM yellow bulbs, w/stone gaurd covers, all new)
Custom yellow center lights (yellow stone gaurds)
OEM Quad headlight grill and core support
Euro VR6 front lip (factory VW parts)
Interior:
Recaro 16v full gray seats
Momo steering wheel
Momo shift ****
VDO 0-30PSI boost gauge
no rear seats but i do have the 'cargo tray'
Optima "Red top" sealed battery
black carpet, dash, black/grey door cards
NO Air conditioning (non-AC car), NO power steering (manual rack).
most the the "new" items have been on the car sence August when we finished the car and probly have like 1000 miles on them...
VIN: 3VWDB21G2MM028580
NO RUST!!!! clean title. unsure on accual mileage of car (most everything has been replaced anyway, cluster pictured is not originally from this car) but when i got it i was told that the motor blew up several years ago and they started to part out the car. quote from CarFax report: "The last odometer reading, reported on 06/27/1997, was 110,000 miles."
i an NOT looking to part out the car. want to sell the car as a whole, but if there are some minor items we can talk...
this is really an awesome car very fun, and hate to sell it but i have made up my mind to sell it to pay off my debts. so im in no big hurry to sell.
this isnt a perfect car, it is a used car so there are some small items like door dings, hood is a little dented (have a new primered ceritfit hood for a little extra). also doesnt currently have an full exhaust, just a resinator at the end of the downpipe with a turndown (not too loud)... if you want i will have a full 3inch exhaust and Magnaflow muffler for $300... has a nice CD player in it that dont work...
compression tested after we got back from the track (dynoed it a couple days before that) at 185psi across, so it is a healthy motor...
17psi on my pump gas tune, and concervitive timing
VIDEO: couple shots from a roll...more soon as we get some time and it stops raining
i have shitloads more pics. pics of damn near everything i bought when it showed up, or was finished being fabbed. if you want to see them just ask, i will find them...
Zentroix Wideband in the pictures is NOT included, for the simple fact that it isnt mine. you might be able to talk me out of my PLX300 wideband for a couple bucks though...
Also currently i have an extra 02A for this car transmission that i will be selling for $200 more...
$8000.....i have TITLE IN HAND...
car is located in Everett, WA 98204. i will not provide shipping, thats your job to arrange.
NO JOY RIDES....
only trade i will consider is for a 92-00 Civic hatch (no rice) NOTHING ELSE...
Old Jan 1, 2006 | 12:53 AM
jdm_ekcivic's Avatar
Default Re: '91 Montana Green GTI turbo 16v....... (turbohf)
I've decided that is the sexiest Monty Green GTI I've ever seen before.
Makes me wish I had a MK2 GTI to mess around with.
Old Jan 4, 2006 | 09:42 AM
Default Re: '91 Montana Green GTI turbo 16v....... (jdm_ekcivic)
Another bump for ya.
Old Jan 5, 2006 | 02:15 PM
turbohf's Avatar
thanks!
hate to see this car go....but the parts for the next project are starting to pile up, and need the space in my driveway/garage...
very much open to trades or offers.... REALLY want a 92-93 CX/VX in white, but any 92-95 Civic hatch is fine (no red, automatics, or rice though)...
Old Jan 5, 2006 | 03:35 PM
damnraz's Avatar
I'll give you $979.00 and not a cent more for it! j/k, fast car you guys I've seen this car in action, free bump for dustin.
Old Jan 7, 2006 | 06:30 PM
turbohf's Avatar
Default Re: '91 Montana Green GTI turbo 16v....... (damnraz)
thanks
turbohf
Mar 8, 2006 05:42 PM
turbohf
Jan 10, 2006 08:25 PM
turbohf
Dec 4, 2005 11:04 AM
turbohf
Oct 4, 2005 03:14 PM
