My 92 Honda Civic
Ok my 92 honda civic idles at under 1000 rpms and bogs when in low rpms, i have slow starts but then it runs great at high rpms, I was wondering if anyone could give me a hint or help me fix this or what i should check or change to get it to run great again?!? I NEED HELP PLZ
You've been a member of last year so I'll help you out
Mine did the same thing. I changed all my belts and dizzy cap and rotor, problem solved for me.
I would also check your idle valve, could be a problem.
Derrrty fuel injectors will also give you ****
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b1886crx »</TD></TR><TR><TD CLASS="quote">Check your timing belt, it could be off a tooth. </TD></TR></TABLE>
That would probably be the last thing. You'd probably have a lot more problems than a bad idle.
Ryan124
Jan 1, 2006 01:43 PM
hybrid92b20
11
Feb 8, 2004 09:56 AM
Rva16v
May 27, 2003 10:50 AM
