Bet you guys didn't know (Some LSD tranny tech)
Old Mar 18, 2002 | 09:50 PM
shamoo's Avatar
Will you make something up for me please?
Default Bet you guys didn't know (Some LSD tranny tech)
After spending countless hours taking the tranny apart and trying to figure out how to fit an LSD from a JDM Type R into an LS trann, I found out something very important.
A while ago, I posted here asking if it would fit. Everyone who knew said all I needed was a final drive ring gear (4.400) from either a GSR or a USDM Type R. Fine, that's easy.
However, when putting in a Type R LSD into an LS tranny, not only do you need that, but you need the entire countershaft from a tranny with a 4.400 final drive!!!
Now I'm going to have to call Acura in the morning and order one next day air. That's another two days my car isn't gonna be on the road. It's also probably going to be another couple hundred $$ too. I coulda just bought a Quaiffe from the beginning, but no. $400 for the LSD, another say $200 for the countershaft....coulda shelled out a few more for the real thing!!!!
Great Spring Break this is.
End rant.
Old Mar 18, 2002 | 09:55 PM
B00ST2nR's Avatar
Default Re: Bet you guys didn't know (shamoo)
damn that sucks
Old Mar 19, 2002 | 09:00 AM
shamoo's Avatar
Default Do you guys know?
Does anyone know if LS gears will fit onto a GSR/Type R countershaft?
I don't want to buy a countershaft if my gears won't even fit onto them...and I don't feel like running GSR/Type R gears in my Turbo LS.
Old Mar 19, 2002 | 04:20 PM
B18C-EJ1
Guest
Posts: n/a
End rant.
Shoulda asked me. I could have told you that. I put a Y1 LSD in my LS. Works beautifully.
4.266 FD, so no mods necessary. Only had to shave the case to fit the LSD properly.
Yes, the LS gears will fit on the GSR/ITR main shaft.
[Modified by B18C-EJ1, 5:20 PM 3/19/2002]
Old Mar 19, 2002 | 07:21 PM
Top_spec's Avatar
Default Re: Bet you guys didn't know (B18C-EJ1)
how do u separate the housings in a b series tranny ive tryed and it doesnt seem to want to seperate
Old Mar 19, 2002 | 08:36 PM
shamoo's Avatar
Default Re: Bet you guys didn't know (Top_spec)
Give it some good hits, it'll come apart. Make sure all the bolts are off, there are quite a few.
Old Mar 20, 2002 | 03:03 AM
samiam's Avatar
Don't for get to hold the snap ring open when you pull it apart.
Old Mar 20, 2002 | 08:32 AM
owen_the_soyboy's Avatar
that sucks monkey ****, sorry to hear the bad break....
best of luck to ya...
Old Mar 20, 2002 | 09:45 AM
VTEC4GS's Avatar
well, too bad you don;t know me and I'm right in Woodbridge NJ and have many extra coutershafts with the 15 teeth to give 4.4 final ... plus I could put tranny together for you ... YIKES !!!
Greg
Old Mar 20, 2002 | 10:26 AM
shamoo's Avatar
Default Re: Bet you guys didn't know (vtec4gs)
Greg
Arghhh!!! Well, I IMed you anyway.
Old Mar 20, 2002 | 12:30 PM
Top_spec's Avatar
whats the snap ring
Old Mar 20, 2002 | 02:01 PM
shamoo's Avatar
The snap ring is a C-clip inside the tranny drain bolt.
When you're trying to put the housing back on, you have to compress the C-clip to get the housing down all the way. It's gonna be hard if you don't have one of those C-clip pliers.
Old Mar 20, 2002 | 03:36 PM
Top_spec's Avatar
ok thanks i will try that agian
really apreciate it
Old Mar 20, 2002 | 05:07 PM
B18poweredhatch's Avatar
so you can install my clutch and flywheel
im from jackson, were you at that meet last saturday?
Old Mar 21, 2002 | 07:24 AM
shamoo's Avatar
Default Re: Bet you guys didn't know (b18c1 dx)
Haha. I'm not that good....YET! By the summer, I guarantee I will do my own clutch install. Right now I can service a tranny, but only if it's off the motor already. Gimme a call in the summer!
Don't worry, my car will be the first guinea pig. My car was the first with my suspension install, now I'm doing everyone's.
eag36
Dec 27, 2005 08:58 PM
Mr.DC2TurBo
Aug 30, 2004 05:35 PM
bottlefedb18c1
Aug 18, 2003 02:24 PM
dkasakitis
Mar 19, 2003 04:39 AM
driftintoacurb
Jan 4, 2003 05:46 PM
