new oil pump leaking
Old Dec 31, 2005 | 03:52 PM
SIXTY's Avatar
Default new oil pump leaking
I swapped from an ls oil pump to a gsr oil pump and now have a leak.
I used a small layer of hondabond around it and it started to leak. Then i pulled it off cleaned it and this time i used a grip of hb, the leak is less but it is still there. It looks to be leaking from around the area of where the plug is on the upper right hand corner. My question is, is there an o-ring that goes around the small oulet hole where the oil goes back into the motor? I searched and did not get much info on this, some say "yes" some also say that all you need is some hondabond. I have done a few of these before and to be honest i have never noticed this. Any info on this subject would be greatly appreciated.
Old Jan 1, 2006 | 08:36 AM
PURPLETERROR aka BIGMATT's Avatar
Default Re: new oil pump leaking (b1886crx)
yes, there should be an o ring there
Old Jan 1, 2006 | 09:53 AM
DC2 Mang's Avatar
Default Re: new oil pump leaking (PURPLETERROR aka BIGMATT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PURPLETERROR aka BIGMATT &raquo;</TD></TR><TR><TD CLASS="quote">yes, there should be an o ring there</TD></TR></TABLE>
check that
Old Jan 1, 2006 | 10:42 AM
SIXTY's Avatar
Thanks for the help!
somick
Aug 15, 2017 08:14 AM
vtec-gorilla
Sep 1, 2006 09:05 PM
ALMXDUPINTEGRA
Jun 22, 2005 05:04 PM
chadwick16
May 21, 2005 10:40 AM
shreddinryguy
May 12, 2005 09:54 AM
