BRAKE LIGHT
I hate everything
There is a peice of plastic down by your breakpedal that allows your lights to go on/off. If that peice of plastic is broken, it will cause them to stay on constantly. Check that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maluseanjohn516 »</TD></TR><TR><TD CLASS="quote">i mean brake light is on in my dash is that becasue of a sensor</TD></TR></TABLE>
You could be low on fluid....But don't add any if you are, check your brake pads to see how thin they are... a safe pad is 5mm and above.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maluseanjohn516 »</TD></TR><TR><TD CLASS="quote">hey thanks man it was that GREAT now that annoying brake light isn;t on all the time</TD></TR></TABLE>
so is this because you replaced a worn part or did you add more fluid? if you did the latter, i hope its because the parts are on order.
ham_yorkwind
Apr 10, 2005 07:43 PM
BigZ88
Feb 21, 2005 09:17 PM
