Resetting check engine light
Old Dec 31, 2005 | 10:40 AM
casmello's Avatar
Default Resetting check engine light
On 6th gens can you just remove the negative terminal or do I have to pull a fuse or both?
*I did a search but couldn't find anything specifically for 6th gen
Old Dec 31, 2005 | 12:30 PM
BLKFLSH's Avatar
Default Re: Resetting check engine light (casmello)
Did you get the codes first? There is a 7.5amp fuse in either the under hood fuse box or the fuse box behind the hood release (should say radio backup, or clock backup, or something to that effect. If you remove the battery cable you will need the radio code to get the radio to come on again (factory radio). If you just do the fuse you will only have to redo the station presets.
PS: you have to remove the fuse for 10 seconds, then replace it. If whatever the light came on for is not fixed, it will probably come back.
Modified by BLKFLSH at 10:56 PM 12/31/2005
Old Dec 31, 2005 | 02:02 PM
vtecpower3088's Avatar
To reset the check engine light you have to unplug the battery only. Make sure though that you have the code for the radio or else it wont start up. Just input the code into the radio and it should be fine.
Old Dec 31, 2005 | 10:56 PM
BLKFLSH's Avatar
Default Re: Resetting check engine light (vtecpower3088)
If you can find the right fuse, you don't have to disconnect the battery.
Cdeese910
Oct 25, 2012 07:56 AM
LoriM
Audio / Security / Video
Jul 9, 2011 04:07 AM
phoenix_iii
Mar 14, 2009 05:01 PM
10KrpmS2K
Honda S2000
Aug 11, 2005 07:36 PM
Spade
Jan 14, 2002 10:29 AM
