**HOW TO WIRE UP A IN-LINE FUEL PUMP??**
i got a inline fuel pump from my friend tonight and i need to know how to wire it up? he told me to tap it in between the filter and the fuel rail.....is this right?? and how can i wire it up so its only on when the normal pump is on?? theres just power and ground.
thanks!
thanks!
use a fuel pump relay bosh makes them most auto parts stores should have them, they should have a wirring diagram, then alls you need is a 12 volt switched source you can find it at the fuse box inside. Good luck, Jason
