Motor swap options for 2001 Coupe EX
Old Dec 30, 2005 | 08:51 PM
rice is nice's Avatar
Default Motor swap options for 2001 Coupe EX
Okay, so this car came with a d17, can you bolt in a b series, or only the k series?
I checked hasport, and they only showed a k20 mount swap, so i'm guessing just the K series, but wanted to know about the b-series.
Old Dec 31, 2005 | 12:57 AM
Curiouz_G's Avatar
the b series is possible but its just as expensive as the K series if not more and plus, who wants old technology?
Old Dec 31, 2005 | 09:13 AM
Default Re: (Curiouz_G)
why would the b series be just as expensive? You mean because of special motor mounts and such? Because last time I checked, the k series motor swap was about 5 grand just for motor, tranny, ecu.
Old Dec 31, 2005 | 11:45 AM
djSALIX's Avatar
Default Re: (beef-cake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beef-cake &raquo;</TD></TR><TR><TD CLASS="quote">why would the b series be just as expensive? You mean because of special motor mounts and such? Because last time I checked, the k series motor swap was about 5 grand just for motor, tranny, ecu.</TD></TR></TABLE>
custom mounts need to be made.
Old Jan 1, 2006 | 07:25 AM
Curiouz_G's Avatar
are u series? any b series swap into a EM2 chass. will cost more than a B series swap. go do some research before you say things like that
Old Jan 1, 2006 | 07:26 AM
Curiouz_G's Avatar
oh yea by the way, the 5 grand for ecu, motor, and tranny is for the k20a2 motor which is the rsx type S motor. the whole swap for a k20a3 could be done for that much.
Old Jan 1, 2006 | 12:55 PM
NoBottleJustThrottle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Curiouz_G &raquo;</TD></TR><TR><TD CLASS="quote">oh yea by the way, the 5 grand for ecu, motor, and tranny is for the k20a2 motor which is the rsx type S motor. the whole swap for a k20a3 could be done for that much.</TD></TR></TABLE>
Actually the 5 grand is for a K20A motor. You can find the A2 motor for as little as 3 grand if not less. You just have to know where to look.
I have only seen one b series in an EM2 and it took boat loads of work. Stick with the K series. I had an A2 in my EM2 when HASport first came out with the mounts. This was back in the day without conversion harnesses, K-pro, and all that stuff to make the swap easy. I had to figure things out for myself. It took me about 11 grand to do it all with all the custom work that had to be done. I think now with a 3 grand A2 motor the whole swap could be done for about 5.5grand if you did the work yourself.
A K20A swap would cost you about 7-8 grand.
Old Jan 1, 2006 | 04:40 PM
ES2's Avatar
ES2
Default Re: Motor swap options for 2001 Coupe EX (beef-cake)
Like others have said, the K20 will probably be the better value. I read somwhere that the k20A2 cyclinder head flows better than a ported b-series head.
Old Jan 2, 2006 | 03:29 AM
Curiouz_G's Avatar
it depends on the mileage of the motor also... your wont want to drop a 40k motor into a car...or i wouldnt
Old Jan 2, 2006 | 09:44 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Curiouz_G &raquo;</TD></TR><TR><TD CLASS="quote">it depends on the mileage of the motor also... your wont want to drop a 40k motor into a car...or i wouldnt </TD></TR></TABLE>
Well if you car has 180,000 miles on it, a 40,000 mile motor sounds pretty damn good.
40,000 on a honda motor is nothing. I always say thats just out of the break in period. My B16A had close to 60,000 miles on it when I got it...no problems. Just keep up with the oil changes, and other maintenance things and you will be fine.
Old Jan 2, 2006 | 11:36 AM
Default Re: (NoBottleJustThrottle)
sounds good. I'll get a 2000 then instead of the 2001.
Thanks.
Old Jan 2, 2006 | 02:53 PM
k20whitevic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NoBottleJustThrottle &raquo;</TD></TR><TR><TD CLASS="quote">
I have only seen one b series in an EM2 and it took boat loads of work. </TD></TR></TABLE>
There are actually several of them. A few were done in Japan, as well as Taiwan. I can only remember of one in Canada as well.
They were all custom jobs, and were a lot more than todays standards.
Old Jan 3, 2006 | 04:05 AM
Default Re: (k20whitevic)
so basically the 2000 civic was a WAY better choice for a b series swap?
Old Jan 3, 2006 | 07:55 AM
djSALIX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beef-cake &raquo;</TD></TR><TR><TD CLASS="quote">so basically the 2000 civic was a WAY better choice for a b series swap?</TD></TR></TABLE>
YES!
jdmdelsolsi
Jun 1, 2006 11:56 PM
gt35r
Northwest (Sales)
Jun 26, 2005 09:37 AM
