heat problem in 1996 coupe after swap
i put the stock motor bak into my 96 coupe and now the adjuster for the hot/cold doesnt go to hot all the way it kinda gets stuck, and the heat doesnt blow through the middle two vents, i think that might be because of the relay under the hood though, anyone have an idea?
ur heater cable might be cought on something or bent its the little black peice on the firewall in the engine bay were the small heater hose from the head goes to it on the firewall check it out
civiccoupegsr
Jul 31, 2007 10:32 PM
Hockey27925
Jan 26, 2006 11:57 AM
