removing intake manifold
Old Dec 30, 2005 | 07:55 PM
EGhatch33's Avatar
Default removing intake manifold
how do u get to the underside nuts on the intake manifold?
Old Dec 30, 2005 | 08:07 PM
nekoabandoned's Avatar
Default Re: removing intake manifold (EGhatch33)
get under the car
Old Dec 30, 2005 | 08:12 PM
Calvinator's Avatar
I was able to reach my hand under the IM and loosen them. My arms arent skinny either.
Old Dec 30, 2005 | 08:13 PM
transpar_nt's Avatar
Step 1: Buy 20 lb. sledge from hardware store.
Step 2: Swing said hammer Paul Bunyan style, placing the blow squarely in the center of the plenum.
Now you have lots of room
Old Dec 30, 2005 | 10:15 PM
DRAMA's Avatar
reach around each side from topside
Old Dec 30, 2005 | 10:28 PM
ABK's Avatar
ABK
Default Re: removing intake manifold (StReEt TuNeR)
buy tools that let you do that, also removing the support bracket helps a hell of alot.
If not pay me or somebody else to do it for you.
Old Dec 30, 2005 | 11:29 PM
97spooncivic's Avatar
Default Re: removing intake manifold (ABK)
you should be able to reach around with the tools. or if your im has gap between the runners, try to loosen them and then use your hand
Old Dec 31, 2005 | 03:32 AM
Jay_Sensing's Avatar
I went from the driver side fender and just reached under. Definate pita so it was removed when the head was taken off.
coreyhayman
Sep 29, 2006 06:38 PM
Aeka GSR
Sep 14, 2003 09:19 PM
HaUTSaauce
Mar 22, 2003 07:06 PM
ARACER25
Oct 15, 2002 10:59 AM
95gsr
Oct 4, 2001 10:12 PM
