94-97 front bumper removal...i'm lost
Old Dec 30, 2005 | 06:38 PM
k-swig's Avatar
Default 94-97 front bumper removal...i'm lost
ok, so i took out every damn screw/bolt/clip that i could find on the front bumper. but there are two under each headlight. [to remove headlight, you need to remove bumper] i took out the bumper lenses, and the bolt behind each. there is another bolt just above the bumper lense hole that i can't get at because it's behind the plastic. i'm at a stand still, with a missing headlight, and the grill, front lip, and under cover off the car.
can anyone help me?
appreciate any help you can give. Thanks
Old Dec 30, 2005 | 08:55 PM
momstaxi's Avatar
Default Re: 94-97 front bumper removal...i'm lost (k-swig)
there are two bolts behind the bumper lenses on each side, 4 total...then, slightly lift up and out and you should remove the bumper cover and support off as one assembly...
racerxfactor
Mar 12, 2007 05:08 AM
accordlx97manual
Feb 7, 2006 07:05 PM
95se4dr
Aug 5, 2004 10:39 PM
project dc2
Nov 25, 2002 07:43 PM
