electric clutch on a SC
Is it possible to put an electric clutch on a SC so that you can control when the pulley is engage I've heard of this being done on a Chevy but is it possible on a Honda??
basically it would allow you to control from in the car when the SC is on. It puts a clutch in the pulley thats attached to the SC, so when the clutch is on, the pulley on the SC is spinning. When the clutch would be off or disengaged the SC would not be spinning or giving boost
Yes you can have an electric clutch on a supercharger. As far as a kit, there isn't one.
Basically, you must buy a supercharger from somewhere. Then, find a pulley that has an electric clutch. Some how you would have to find out how much boost you would create with that pulley.
I've seen this set-up done, good luck.
Thank you!
I was like what the hell is this guy talking about lol couldent you take the pully or something off of say an A/C unit and use that? I remember messing around with something like this a few yrs ago but lost interest because of lack of modivation. Its basicly the same thing as riding lawn mowers use as well for the deck engagements. I'm sure its been done before. You might have better luck asking in the forced induction forum.
Good luck either way
most screw type superchargers are sealed and wont run that well without the screws turning. now a vortech, being a centrifugal, it can breathe, not that well, but it can without it turning. mad max did it but i do believe that it wasnt a positive displacement blower.
exactly what i was thinking, it wouldn't to anything but hurt your porfarmance. with it on in low rpms, your still atleast spinning it, with it off , yes it would stop paracitic (sp) drag, but you would drastically slow the air flow. Its like having a button that gives you a flat tire, why?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG93si »</TD></TR><TR><TD CLASS="quote">exactly what i was thinking, it wouldn't to anything but hurt your porfarmance. with it on in low rpms, your still atleast spinning it, with it off , yes it would stop paracitic (sp) drag, but you would drastically slow the air flow. Its like having a button that gives you a flat tire, why?</TD></TR></TABLE>
I like that analogy
I like that analogy
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vintech »</TD></TR><TR><TD CLASS="quote">why have a supercharger on a button. Bump for the AC pulley idea. Most use a electomegnectic clutch, i can't spell</TD></TR></TABLE>
electromagnetic
electromagnetic
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97spooncivic »</TD></TR><TR><TD CLASS="quote">some guy did this to his subaru. it was tt and sc</TD></TR></TABLE>
I'd like to see a shot of that engine bay
Yes, that works actually. VW is doing that from the factory in the European Golf (Polo?), they're calling it the "TwinCharger" system. There's an electromagnetic clutch on the SC, exactly like you'd find on an A/C compressor.
There's also a diverter valve that sends intake air though the supercharger at low RPM's. At high RPM's, the diverter valve moves to divert air through the turbocharger instead of the SC, and provides high-RPM power. At this point, the SC clutch is disengaged and the SC is completely cut out of the loop.
The end result is great low-end torque balanced with great high-RPM power. Although very expensive to build, it also works wonders for fuel economy. I believe they get about 170hp and 200ish ft-lbs out of a 1.4-liter engine, all while acheiving an advertised 40+ mpg.
That being said, I don't believe that VW's TwinCharger system is going to be shipped to the American market...although I could be wrong.
