what are the 2 wires for (below map sensor)
i just got my rywire conversion harness so im starting to plug up all the wires.....well the conversion doesnt have a plug for the map sensor(left a message @ rywire). my wiring was already a mess, i have a buch of wires coming from my firewall, so it looks like i need to wire up the map sensor.....i know the map sensor is just 3-wires (but i cut a clip from a car at the junkyard) and below the 3-pin plug there is a 2-pin plug(green w/black, and black w/yellow) what does the 2 wire plug go to? and is it needed on an obd-1 conversion???
im still searching and i found this: https://honda-tech.com/zerothread?id=1142577 the 1st reply says i wouldnt need it...is that true?? (im tryin to do this without throwing any codes)
2-wire plug with black/yellow and green wires is for the Purge Cutoff Solenoid Valve, which is the thing right beside the MAP in your picture - do you need it for car to run? no - do you need it to pass visual on emissions? maybe - don't know what is required where you are
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx »</TD></TR><TR><TD CLASS="quote">2-wire plug with black/yellow and green wires is for the Purge Cutoff Solenoid Valve, which is the thing right beside the MAP in your picture - do you need it for car to run? no - do you need it to pass visual on emissions? maybe - don't know what is required where you are</TD></TR></TABLE> thanks for the reply! do you know where the Purge Cutoff Solenoid Valve would be on a z6? and also is there a special way i need to wire up the map sensor? (or can i just match the wires?(color for color)
on the Z6, the purge cut-off solenoid is on the back of the intake manifold on the driver's side - match wire colors for MAP
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx »</TD></TR><TR><TD CLASS="quote">on the Z6, the purge cut-off solenoid is on the back of the intake manifold on the driver's side - match wire colors for MAP</TD></TR></TABLE>thanks!!!
JDMlyfestyle
Oct 17, 2004 05:27 PM
ImprtRcr02
Feb 26, 2004 01:43 PM
