b20 VTEC CAMS?
Old Dec 30, 2005 | 12:33 PM
Dallio's Avatar
Default b20 VTEC CAMS?
I have a B20 with GSR head, I was currnetly running Toda B cams in this car. They worked o.k but Friends of mine are running Skunk stage 2 and they are making more power. Is the skunk cam the way to go? or is there a better cam that is recomended. This is a street car only. Im not racing car, just to put in my garage and drive on sundays. I allready have Supertec valve springs and retainers, aswell as Ferrera Valves. Skunk2 (PRO SERIES) Intake manilfod, and SKunk2 70 mm throttle body, full fuel system, stock ignition, usually tuned with wide band.
Please help
Thank you for your help and Time
Old Dec 31, 2005 | 03:28 PM
2000EM1's Avatar
Default Re: b20 VTEC CAMS? (Dallio)
skunk 2 stage two's aren't going to do anything for you unless you build the engine to run a higher CR.
Basically you want to build the engine to be able to use the power they're going to help you make.
kil2002
14
Oct 26, 2009 03:55 AM
Dallio
Dec 25, 2005 04:32 AM
88crx Osaka
22
Oct 25, 2005 05:11 PM
