HOW TO WIRE VTEC ON P28...I HAVE SEARCH, NO LUCK
Old Dec 30, 2005 | 11:36 AM
lv6l's Avatar
Default HOW TO WIRE VTEC ON P28...I HAVE SEARCH, NO LUCK
i have 94 civic cx with d16a and p28 ecu. i want to wire vtec. my swap came with the electric harness intact and i want to wire the (3) wires on the solinoid through my firewall straight into my ecu, problem is i dont knwo which wire goes where? can someone tell me what are the 3 wire on the soilnoid are?? i ahve search many times, i know in the past there are many threads, i never printed them out or anything thinking they will always be there but now its all gone. so i need help. thanks.
Old Dec 30, 2005 | 11:48 AM
SkoundrelUSA's Avatar
cute little bastard
Default Re: HOW TO WIRE VTEC ON P28...I HAVE SEARCH, NO LUCK (lv6l)
try these
https://honda-tech.com/zerothread?id=682412 scroll down pass the codes
https://honda-tech.com/zerothread?id=724252
Old Dec 30, 2005 | 11:51 AM
lv6l's Avatar
the first link said its for b-series motor, would be d16a and p28 work??
Old Dec 30, 2005 | 12:01 PM
IHateJDM's Avatar
Default Re: (lv6l)
Solenoid goes to A4
Pressure switch + to D6
Pressure switch - either grounded to chassis or A26
Old Dec 30, 2005 | 12:11 PM
Turbogixxer's Avatar
Default Re: (lv6l)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lv6l &raquo;</TD></TR><TR><TD CLASS="quote">the first link said its for b-series motor, would be d16a and p28 work??</TD></TR></TABLE>
The motor does not matter, it is for the ECU.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IHateJDM &raquo;</TD></TR><TR><TD CLASS="quote">Solenoid goes to A4
Pressure switch - either grounded to chassis or A26</TD></TR></TABLE>
Old Dec 30, 2005 | 12:13 PM
Luserkid's Avatar
Default Re: (IHateJDM)
WINNER!
Old Dec 30, 2005 | 02:22 PM
lv6l's Avatar
thanks a lot
i have 3 wire, can someone tell me which is the solinoid, which is the preassure switch and which is ground
off the green plug = blue/black & black
off the gray pug = green/yellow
Modified by lv6l at 3:51 PM 12/30/2005
Old Jan 2, 2006 | 05:20 AM
IHateJDM's Avatar
Default Re: (lv6l)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lv6l &raquo;</TD></TR><TR><TD CLASS="quote">off the green plug = blue/black & black
solenoid is the gray one wire plug and pressure switch is the 2 wire plug.
.:TNN:RumbleN:.
Jun 7, 2005 05:41 PM
lmiguelvv
Nov 10, 2004 08:59 PM
B_CRUZ!
22
May 13, 2004 09:00 PM
InfamousRS
May 19, 2002 10:56 AM
