OIL LEAKING FROM OIL PRESSURE SENSOR LOCATION PLEASE HELP FAST !!!!
Old Dec 30, 2005 | 11:32 AM
93CharcoalHatch's Avatar
Default OIL LEAKING FROM OIL PRESSURE SENSOR LOCATION PLEASE HELP FAST !!!!
i was going to install a firewall relocation kit but decided to put the stock sensor back in. started the car and it leaks from the oil pressure sensor hole.. it is a B18B in a 93 civic.. what can i do??? PLEASE HELP!!!
Old Dec 30, 2005 | 11:42 AM
Default Re: OIL LEAKING FROM OIL PRESSURE SENSOR LOCATION PLEASE HELP FAST !!!! (93CharcoalHatch)
ok i have a feeling im prety fucked because the leak looks like its coming from an area on the block to the side of the oil pressure sensor ? it doesnt look like its coming from the threads ? is this a possibility? if so ehat couldve happened and what can i do ?
Old Dec 30, 2005 | 11:45 AM
DJ Gurgla GSR's Avatar
pretty sure that sensor needs teflon tape or honda bond on the threads to seal properly
pull it, clean it with a rag, give it a squeeze of hondabond on the threads, put it back in, let it chill for long time. then see if it leaks
Old Dec 30, 2005 | 11:47 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93CharcoalHatch &raquo;</TD></TR><TR><TD CLASS="quote">ok i have a feeling im prety fucked because the leak looks like its coming from an area on the block to the side of the oil pressure sensor ? it doesnt look like its coming from the threads ? is this a possibility? if so ehat couldve happened and what can i do ? </TD></TR></TABLE>
Old Dec 30, 2005 | 11:50 AM
well i'm not looking at it so i can't really do much without pics
check what i said above
Old Dec 30, 2005 | 11:53 AM
ok it looks like there is a small crack.. what can i do? im going to try to take a pic
Old Dec 30, 2005 | 12:05 PM
Default Re: OIL LEAKING FROM OIL PRESSURE SENSOR LOCATION PLEASE HELP FAST !!!! (DJ Gurgla GSR)
ok theres no way i can get a picture so im going to try to explain it in detail... the area on the back of the block is "raised" where the oil pressure sensor screws in.. there is a smallll crack on the raised part.. does anyone know anything i can put on it to seal it ? ANY ideas ?
Old Dec 30, 2005 | 01:00 PM
hey i just threw some JB weld on it i guess ill let everyone know what happens.. its a VERY TINY crack.. well see
Old Dec 31, 2005 | 09:36 AM
leaked slowed but its still there.. cleaned it up and threw some more JB weld on it.. theres no way im gonna be able to trust it long distances, etc. you know what i mean? any ideas? i called a local shop and they seemed to know what i was talking about right away so im guessing it happens.. but in order for them to weld it they would have to take off the intake manifold, etc. to get to it which would lead to some crazy labor.. is there anything else i can do ? and has anyone ever had theirs welded? and if so how much were you charged? or if anyone would like to throw some prices at me let me know
Old Jan 2, 2006 | 10:25 AM
ok JB weld didnt work.. if anything its worse lol.. has anyone ever used "alumaloy" ? i see they can even repair engine mounts with it. Does anyone know anything about this stuff ??
Old Jan 2, 2006 | 04:17 PM
Old Jan 2, 2006 | 04:48 PM
98 Spec R's Avatar
I have seen this before, when people over torque that sensor. I would prep the surface very well before using the adhesives you are talking about. I have fixed a few cracked tranny cases using JB Weld. The key was the prep before applying the adhesive, the surface must be completely oil free and have a slightly roughed up area to bond to. Good Luck
Old Jan 2, 2006 | 08:16 PM
mmuller's Avatar
Mad Scientist
Default Re: OIL LEAKING FROM OIL PRESSURE SENSOR LOCATION PLEASE HELP FAST !!!! (98 Spec R)
grind, cover the hole and get your oil from a sandwich adapter.
Or you can take the engine out and get it welded.
Old Jan 4, 2006 | 08:55 AM
Default Re: OIL LEAKING FROM OIL PRESSURE SENSOR LOCATION PLEASE HELP FAST !!!! (mmuller)
anyone know how to get JB weld off easy ?
Old Jan 4, 2006 | 10:29 AM
runeminaEF9's Avatar
yer probly gonna have to grind the jb weld off. if you can find someone who can do a small weld for you, then remove the intake manifold yourself and do it.
Old Jan 5, 2006 | 09:04 AM
Default Re: OIL LEAKING FROM OIL PRESSURE SENSOR LOCATION PLEASE HELP FAST !!!! (runeminaEF9)
any more ideas?
Old Jan 6, 2006 | 08:12 AM
Old Jan 6, 2006 | 09:42 AM
ComptonsF1NEST's Avatar
buy a new block...probably will be the same price if u get the shop to do it
07CRV
Honda CR-V & Element
Sep 30, 2016 04:07 AM
93CharcoalHatch
24
Jan 9, 2006 04:19 AM
89civicdxracer
10
Jan 14, 2005 11:05 AM
jaysonx
Sep 8, 2003 08:21 PM
Canuk_SiR
Aug 1, 2002 12:16 PM
