OIL LEAKING FROM OIL PRESSURE SENSOR LOCATION PLEASE HELP FAST !!!!
Old Dec 30, 2005 | 11:31 AM
93CharcoalHatch's Avatar
Default OIL LEAKING FROM OIL PRESSURE SENSOR LOCATION PLEASE HELP FAST !!!!
i was going to install a firewall relocation kit but decided to put the stock sensor back in. started the car and it leaks from the oil pressure sensor hole.. it is a B18B in a 93 civic.. what can i do??? PLEASE HELP!!!
Old Dec 30, 2005 | 11:33 AM
snatch's Avatar
Default Re: OIL LEAKING FROM OIL PRESSURE SENSOR LOCATION PLEASE HELP FAST !!!! (93CharcoalHatch)
Did you thread it in correctly? Crossthreaded? Use any teflon tape when you reinstalled it (not sure if you're supposed to or not, I did).?
Old Dec 30, 2005 | 11:34 AM
kyden's Avatar
you can try using some teflon tape or thread sealer.
Default Re: OIL LEAKING FROM OIL PRESSURE SENSOR LOCATION PLEASE HELP FAST !!!! (******)
it threaded in fine and i did use a little teflon tape.. maybe ill take it out and try more tape?
Old Dec 30, 2005 | 11:41 AM
ok i have a feeling im prety fucked because the leak looks like its coming from an area on the block to the side of the oil pressure sensor ? it doesnt look like its coming from the threads ? is this a possibility? if so ehat couldve happened and what can i do ?
Old Dec 30, 2005 | 11:49 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93CharcoalHatch &raquo;</TD></TR><TR><TD CLASS="quote">ok i have a feeling im prety fucked because the leak looks like its coming from an area on the block to the side of the oil pressure sensor ? it doesnt look like its coming from the threads ? is this a possibility? if so ehat couldve happened and what can i do ? </TD></TR></TABLE>
and to top it all off its getting dark
Old Dec 30, 2005 | 11:54 AM
ok it looks like there is a small crack.. what can i do? im going to try to take a pic
Old Dec 30, 2005 | 11:57 AM
Archidictus's Avatar
Unceasing Measure
You're supposed to use Hondabond, not Teflon Tape, on the oil pressure sending unit and sensor.
As for your crack, well, that's unfortunate. Take pictures and maybe we can help you.
Old Dec 30, 2005 | 12:04 PM
Default Re: OIL LEAKING FROM OIL PRESSURE SENSOR LOCATION PLEASE HELP FAST !!!! (Archidictus)
ok theres no way i can get a picture so im going to try to explain it in detail... the area on the back of the block is "raised" where the oil pressure sensor screws in.. there is a smallll crack on the raised part.. does anyone know anything i can put on it to seal it ? ANY ideas ?
Old Dec 30, 2005 | 12:06 PM
snatch's Avatar
JB Weld?
Old Dec 30, 2005 | 12:27 PM
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93CharcoalHatch &raquo;</TD></TR><TR><TD CLASS="quote">ok theres no way i can get a picture so im going to try to explain it in detail... the area on the back of the block is "raised" where the oil pressure sensor screws in.. there is a smallll crack on the raised part.. does anyone know anything i can put on it to seal it ? ANY ideas ?</TD></TR></TABLE>
So you split the block, damaging the oil passage. That sucks hardcore. You might be able to get it welded, but if you did enough damage in that area, you might have to get a whole new block.
Be more careful next time.
Old Dec 30, 2005 | 12:59 PM
hey i just threw some JB weld on it i guess ill let everyone know what happens.. its a VERY TINY crack.. well see
Old Dec 30, 2005 | 01:13 PM
turbotime's Avatar
did the block split cause you overtightened the sensor or becuase of how u were dirving or something?
Old Dec 30, 2005 | 01:27 PM
Default Re: (turbotime)
im guessing i over tightened it
Old Dec 31, 2005 | 09:35 AM
leaked slowed but its still there.. cleaned it up and threw some more JB weld on it.. theres no way im gonna be able to trust it long distances, etc. you know what i mean? any ideas? i called a local shop and they seemed to know what i was talking about right away so im guessing it happens.. but in order for them to weld it they would have to take off the intake manifold, etc. to get to it which would lead to some crazy labor.. is there anything else i can do ? and has anyone ever had theirs welded? and if so how much were you charged? or if anyone would like to throw some prices at me let me know
Old Dec 31, 2005 | 10:06 AM
moomakudafi's Avatar
if it were me i would swap out the block. im all about keeping stuff reliable. i dont know how reliable welding the block is but i know putting one thats not cracked in there is good but if you have to pay someone to do the swap then that could be expensive. what it comes down to is that if you cant fix/do it yourself, its gonna cost you some cash
Old Dec 31, 2005 | 10:28 AM
ABK's Avatar
ABK
Default Re: OIL LEAKING FROM OIL PRESSURE SENSOR LOCATION PLEASE HELP FAST !!!! (moomakudafi)
find a local guy that can weld aluminum. take off the intake matifold and have him weld that crack shut.
Old Jan 2, 2006 | 10:24 AM
Default Re: OIL LEAKING FROM OIL PRESSURE SENSOR LOCATION PLEASE HELP FAST !!!! (ABK)
ok JB weld didnt work.. if anything its worse lol.. has anyone ever used "alumaloy" ? i see they can even repair engine mounts with it. Does anyone know anything about this stuff ??
Old Jan 2, 2006 | 04:18 PM
Old Jan 4, 2006 | 08:56 AM
anyone know how to get JB weld off easy ?
Old Jan 5, 2006 | 09:04 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93CharcoalHatch &raquo;</TD></TR><TR><TD CLASS="quote">anyone know how to get JB weld off easy ? </TD></TR></TABLE>
Old Jan 6, 2006 | 08:11 AM
Old Jan 8, 2006 | 08:38 PM
Sloshy's Avatar
ok jb weld shoutld just crack of if you just hit it with a screw driver....
oh yeah im having the same problem just today the whole day i put that block in and got it runnin perfectly no high or jumppy idle so i was happy but then i notice the leak and iwas like, wtf! i thouygh it wsa the drain that was lose check it was goo. then i check the filter, it was good too. and then i saw that crack on the sensor so i know im expletive i just finish rebuildin it so it sucks, im depressed now. im just gettin a new block
Old Jan 9, 2006 | 03:30 AM
Default Re: OIL LEAKING FROM OIL PRESSURE SENSOR LOCATION PLEASE HELP FAST !!!! (hatch-E-vanish)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatch-E-vanish &raquo;</TD></TR><TR><TD CLASS="quote">ok jb weld shoutld just crack of if you just hit it with a screw driver....
oh yeah im having the same problem just today the whole day i put that block in and got it runnin perfectly no high or jumppy idle so i was happy but then i notice the leak and iwas like, wtf! i thouygh it wsa the drain that was lose check it was goo. then i check the filter, it was good too. and then i saw that crack on the sensor so i know im expletive i just finish rebuildin it so it sucks, im depressed now. im just gettin a new block</TD></TR></TABLE>
damnit
Old Jan 9, 2006 | 04:19 AM
v4lu3s's Avatar
RTFM
just have it welded. anyone who is half decent at welding can safely weld aluminum.
96_RHD_EK
Feb 6, 2008 06:32 AM
93CharcoalHatch
Jan 6, 2006 09:42 AM
TURBO DC2
May 26, 2005 01:00 PM
Canuk_SiR
Aug 1, 2002 12:16 PM
