power steering and so fourth
Old Dec 30, 2005 | 11:27 AM
digital sol's Avatar
Default power steering and so fourth
i was wondering what kinda power difference there is with or without power steering. i always hear people say that removing power steering frees up some pony's. My question is, how many pony's are we talking?
i havnt had power steering on my car but miss it, it was fine at first but after driving a regular car with PS, i miss it.
im thinking of putting the power steering system back on
Old Dec 30, 2005 | 11:45 AM
Chris F's Avatar
Default Re: power steering and so fourth (digital sol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by digital sol &raquo;</TD></TR><TR><TD CLASS="quote">i was wondering what kinda power difference there is with or without power steering. i always hear people say that removing power steering frees up some pony's. My question is, how many pony's are we talking?</TD></TR></TABLE>
Did you bypass the pump completely, or just take the belt off?
With the pump bypassed and the rack drained, the steering effort is greatly reduced.
-Chris
rcar97's Avatar
Having the P/S diconnected does pretty much nothing unless you have a lightweight crank pulley that only runs the alt. If my car came with P/S I would leave it unless you change out the steering rack to a manual one. If its a street car than be prepared to wear out you front tires... at least you'll have ripped arms!
Old Dec 30, 2005 | 11:49 AM
Default Re: power steering and so fourth (rcar97)
basically i just moved the belt and compressor, the lines and everything are still there.
i didnt have the right mount for to mount the PS pump to the block and i had to pass inspection so i just removed the pump and left everything else
if i wanted to re-install it, id just have to install the pump, and get a belt
i daily drive my car and its just a huge pain sometimes without power steering, i heard without PS car makes more power, but havnt seen any facts on that........
Old Dec 30, 2005 | 11:50 AM
Reid's Avatar
Global Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rcar97 &raquo;</TD></TR><TR><TD CLASS="quote">Having the P/S diconnected does pretty much nothing unless you have a lightweight crank pulley that only runs the alt.</TD></TR></TABLE>
Wrong, the steering feedback is greatly increased.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rcar97 &raquo;</TD></TR><TR><TD CLASS="quote">If my car came with P/S I would leave it unless you change out the steering rack to a manual one.</TD></TR></TABLE>
You admit to not even having any first-hand knowledge of the subject matter, so why bother to comment? The steering rack on P/S equipped cars is quicker, so swapping to a non-P/S rack is a downgrade.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rcar97 &raquo;</TD></TR><TR><TD CLASS="quote">If its a street car than be prepared to wear out you front tires...</TD></TR></TABLE>
Again, you don't know what you're talking about.
Old Dec 30, 2005 | 01:00 PM
PM-Performance's Avatar
Default Re: power steering and so fourth (Reid)
taking the belt off will feel diff then actually removing it all. Removing it all gives it a little better feel then with the belt off. But it can be a pita sometimes. You get a little jerkiness or pull into turns when removed.
Old Dec 30, 2005 | 01:15 PM
Bbasso's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reid &raquo;</TD></TR><TR><TD CLASS="quote">Wrong, the steering feedback is greatly increased.</TD></TR></TABLE>
AMEN!
Dare I say it's one of those things that should be removed for track duty?
Old Dec 31, 2005 | 04:06 AM
ITRnorway's Avatar
Default Re: power steering and so fourth (Bbasso)
https://honda-tech.com/zero...age=1
7whp and 10ft-lp@3000rpm increase is good for a mood almost for free and no tuning needed
skcivic4life
64
Oct 30, 2007 06:05 PM
FcUK It.
Oct 9, 2003 03:23 PM
