help!!, removing the low beam bulbs
Old Dec 30, 2005 | 07:55 AM
LSBeast's Avatar
Default help!!, removing the low beam bulbs
96 s module prelude
So I've done all the searches but cant come up on anything.
I need some help taking out the low beam headlights. Is there
something that needs to be removed to take the bulbs out??
Old Dec 30, 2005 | 08:00 AM
The Weather Man's Avatar
Just turn and pull. The unplug the bulb........??? If you can't turn it, get a flat head and a mallet. Hit it on the side and it should turn.
Old Dec 30, 2005 | 10:06 AM
kb798's Avatar
Take out the female bulb harness, and then you should be able to see that the bulb is secured by a metal spring. Push down and pull out on the spring, and the bulb should become loose by then.
Old Dec 30, 2005 | 11:45 AM
LSBeast's Avatar
Default Re: (kb798)
Thx for the help up to this point.
This is where I'm at.
I took out both low beams. I swapped them to see it the good bulb would work
and nothing. Does it matter what side they are in and does it matter if I'm testing it
while its dangling on the bulb harness. Does it have to be locked into the actual headlight just to test it? I pulled out the high beam to see if it was a diffierent bulb
and sure enough it is. Now all three don't work. I'm going crazy over here. Feel like
a jack a@@. Can I get some more help on this.
thx
Old Dec 30, 2005 | 01:30 PM
LSBeast's Avatar
Default Re: (LSBeast)
replaced and working now
thx for the help guys!
dwss
Honda Civic (2001 - 2005)
Jul 22, 2008 08:20 AM
xkrntamax
Jul 31, 2006 08:22 AM
Zion-I
Jul 16, 2006 09:34 PM
UntouchableEX
May 19, 2005 07:56 AM
AzntstyleZ
Jan 30, 2004 11:51 AM
