Floating wrist pins?
Old Dec 30, 2005 | 04:40 AM
DarkTeg94's Avatar
Default Floating wrist pins?
If my rods are said to have Bushed Fit Pins - Floating, does that mean I need to buy a piston that has a floating wrist pin?
Which ones should I be looking at getting if that's the case. If I'm right, CTR pistons do not have floating wrist pins correct?
Old Dec 30, 2005 | 05:32 AM
danthemang3's Avatar
Default Re: Floating wrist pins? (DarkTeg94)
floating writs pin means the wrist pin is not pressed onto the rod or the piston, it is allowed to move freely in both. unlike oem, i'm not sure if it's pressed onto the rod or the piston though if somebody wants to chime in.
Old Dec 30, 2005 | 06:42 AM
juicy629's Avatar
Default Re: Floating wrist pins? (danthemang3)
all oem combonations have pressed wrist pins.. floating being an aftermarket thing.. which is a very good idea.. most machine shops will tell you they are unable to remove pressed wrist pins without egg shelling the piston.. even with a jig..
Old Dec 30, 2005 | 10:30 PM
Trench_Rat's Avatar
its pretty difficulkt to press the pin out so its not really worth trying , on the upside though you dont have to buy expensive forged pistons to run a floating pin , you can get little teflon buttons made up that sit into the wrist pin and allow the pin to slide around. If the come out far enough they will just touch the bore and slide back in , its much better than circlips which can pop out and kill your engine.
Old Jan 7, 2006 | 06:42 AM
DarkTeg94's Avatar
Default Re: (Trench_Rat)
So, if I get this right....
If I have a set of aftermarket forged rods that are brand new and I get a set of brand new CTR pistons, can I just run a floating wrist pin in the piston? And how would I do that?
JDMCRX
Mar 15, 2009 05:20 PM
D-SOHC 05
Nov 16, 2007 05:20 AM
Flexin5
Nov 9, 2005 05:08 PM
gaskleppie
Apr 14, 2004 09:34 AM
gsrcivict
Apr 10, 2003 07:22 AM
