Differences between Type S & Type R??
Old Dec 29, 2005 | 08:43 PM
Honda Type R's Avatar
Default Differences between Type S & Type R??
I searched and either I suck at the internet or there is no info. I know the cams and intake mani are different, is there anything else? Is it worth the extra cash to get the JDM K20 or is the USDM one just as good?
Thanks for the help
Old Dec 29, 2005 | 10:12 PM
astig* DC2's Avatar
Default Re: Differences between Type S & Type R?? (Honda Type R)
simply put..TYPE R IS faster and more expensive lol
Old Dec 29, 2005 | 10:24 PM
penguin's Avatar
It's a whole letter faster!
Old Dec 30, 2005 | 05:50 AM
George Knighton's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda Type R &raquo;</TD></TR><TR><TD CLASS="quote">Is it worth the extra cash to get the JDM K20 or is the USDM one just as good?</TD></TR></TABLE>
It's pretty easy to get a K20A* (DC5 Type R) motor up to around 240 wheel horses with just a good computer. There must be substantial cam, intake and head design differences for it to be able to do that.
Old Dec 30, 2005 | 08:50 AM
BoBoChan's Avatar
Default Re: Differences between Type S & Type R?? (George Knighton)
k20a2 [ 02-04 type-s motors ] dont have the type r final drive while the
k20z1(?) [ 05-06 type-s motors ] do
Old Dec 30, 2005 | 12:01 PM
ebp_dc2's Avatar
ok differences lie in the cams, intake manifold, higher compression pistons, different ecu
Old Dec 30, 2005 | 02:18 PM
Thanks everyone
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by George Knighton &raquo;</TD></TR><TR><TD CLASS="quote">
It's pretty easy to get a K20A* (DC5 Type R) motor up to around 240 wheel horses with just a good computer. There must be substantial cam, intake and head design differences for it to be able to do that.</TD></TR></TABLE>
I'm guessing you would have to do cams, pistons, and all that good stuff to get a Type S up that high? All Type R internals will fit in a Type S right? Is the final drive the only thing different between the trannies? Sorry for all of the questions, I've just recently became interested in the K series motors.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoBoChan &raquo;</TD></TR><TR><TD CLASS="quote">k20a2 [ 02-04 type-s motors ] dont have the type r final drive while the
k20z1(?) [ 05-06 type-s motors ] do</TD></TR></TABLE>
So the ITR final drive is available at my local Acura dealer, thats awesome
Old Dec 30, 2005 | 09:11 PM
BoBoChan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda Type R &raquo;</TD></TR><TR><TD CLASS="quote">Thanks everyone
So the ITR final drive is available at my local Acura dealer, thats awesome </TD></TR></TABLE>
is that true? i onno, i would assume so because its on the 05-06 but im not sure.
can someone verify?
Old Dec 31, 2005 | 06:00 AM
Default Re: Differences between Type S & Type R?? (BoBoChan)
can someone verify?</TD></TR></TABLE>
If it comes on/in a car in the US it better be available at the dealer, I'll be pissed if its not
Old Dec 31, 2005 | 06:23 AM
H-T Order of Merit
Yes, the higher numerical "ITR" axle ratio was delivered in the USDM EP3 Si (for all years 2002-2005) and the USDM DC5 Type S (for 2005 and 2006).
You can buy that ring/pinion from any Honda or Acura dealer.
There is also a 5.00 axle ratio available for these transmissions because of the USDM CRV K24.
Old Dec 31, 2005 | 06:28 AM
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda Type R &raquo;</TD></TR><TR><TD CLASS="quote">I'm guessing you would have to do cams, pistons, and all that good stuff to get a Type S up that high? All Type R internals will fit in a Type S right? </TD></TR></TABLE>
You can approximate the results, yes. However, there are a number of other incremental changes to the K20A* motor that are different from the K20A2 motor. It would not be cost effective finding these parts just to be able to have the higher redline more reliably, and you're going to find that the cost of bearings and rods to be prohibitive.
It's not all that expensive to get a complete K20A* motor if you are determined to have the DC5 ITR motor.
The user "Nikos" is a good resource on all K motor affairs, if you want to ask him directly. The moderator "B18Cxr" is also a good resource for anything K motor related. Both of them have already made enough mistakes with K motors that they'd be helpful keeping you from making the same mistakes, and in the case of "B18Cxr" he also has a shop that might prove useful to you in your future builds.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Is the final drive the only thing different between the trannies? Sorry for all of the questions, I've just recently became interested in the K series motors.</TD></TR></TABLE>
To turn a Type S transmission into an ITR transmission, you'd just want to change the axle ratio and add a factory Torsen unit. Both are available quite cheaply. You'll find the Torsen units on eBay all the time for just a few hundred dollars.
Old Jan 3, 2006 | 03:44 AM
I found the Type R K20A for $5600 and the Type S K20A2 for $4000 on H-Motors Online, are those good prices?
Old Jan 3, 2006 | 12:25 PM
Bluewind's Avatar
To set things straight, differences include: No sunroof, full cloth interior/Recaro, Brembo brake system, aluminum lca's, sways, exhaust system, suspension, exterior pieces, 11.5 compression ratio from pistons, more aggressive cams, better flowing head, valve/spark plug cover, 4.7 fd in oppossed to our 4.3, gearings 5 and 6 are shorter, flywheel, intake manifold, and HIDs with black housings.
Make your own decision based off this information.
Modified by Bluewind at 12:43 AM 1/4/2006
Old Jan 4, 2006 | 06:14 AM
Default Re: (Bluewind)
I was talking about dfferences between the motors, but I was curious about the differences between the cars themselves. Thank you for that info
kamranm3
Sep 30, 2010 09:10 PM
leroyb
Mar 16, 2008 10:04 AM
B18C5-EH2
19
Sep 14, 2007 01:08 PM
ThinHoanG
22
Apr 20, 2005 08:39 PM
DC5AM
Feb 8, 2005 05:48 AM
