rywire obd0 vtec sub harness
Old Dec 29, 2005 | 07:38 PM
si0385.'s Avatar
Default rywire obd0 vtec sub harness
has anybody done this... ive heard alot of good things about rywire.com but it doesint say much about the harness... do i need to use a obd0 vtec ecu do i still need a 4 wire o2 sensor... ect.
Old Dec 29, 2005 | 10:02 PM
EF'n Sedan's Avatar
Default Re: rywire obd0 vtec sub harness (jaydeum4lyfe)
curious.......bump!
Old Dec 29, 2005 | 11:31 PM
court's Avatar
25 Year Member
Default Re: rywire obd0 vtec sub harness (spOOLin iT)
your 02 should be dependent on the ecu being used, not the jumper. the jumper dicates what ecu is going to be used ie obd0-obd1, you would be runing an obd1 ecu on an obd0 chasis, like and ef or an early da, possibly even a first gen integra. your quest for which ecu to be used is in the part. if you are buying a 0 to 1 harness, get an obd1 ecu. if you are getting a 2 to 1 harness, get an obd1 ecu. catch on? 4 wire on obd1/2, 2 wire on pr3/pr4, 1 wire on pm6
Old Dec 30, 2005 | 04:58 PM
si0385.'s Avatar
Default Re: rywire obd0 vtec sub harness (court)
i saw the guy from rywire on here one day but his i/m is dissabled and there is no contact or tech help on his site... anyone know how to get ahold of him?
Old Dec 30, 2005 | 05:05 PM
ArtyG's Avatar
They have contact e-mails on the Rywire page near the bottom.
Old Dec 30, 2005 | 05:42 PM
si0385.'s Avatar
Default Re: rywire obd0 vtec sub harness (ArtyG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ArtyG &raquo;</TD></TR><TR><TD CLASS="quote">They have contact e-mails on the Rywire page near the bottom.</TD></TR></TABLE>
didint notice that thanks
Old Dec 30, 2005 | 07:14 PM
91 crx savage's Avatar
My crx is rywired...
Z0831xiz
18
Jul 30, 2013 07:49 PM
88_hatch_ls
10
Jul 28, 2013 08:40 AM
ITA50
Apr 9, 2007 05:16 PM
JDM B16A
11
Jun 20, 2006 09:50 AM
