Evans Tuning shop sale (Full Race, Hasport, PWR, RSX shortblock, injectors, boost controllers, K ser
MyChron3 Plus --It can acquire RPM, speed, 5 analog inputs (pressures, temperatures, gear number, etc.), and lap time. It has an internal data logger with 512 kb for PLUS version and comes with powerful software RACE STUDIO 2. MyChron 3 Plus is 4 analog inputs (Pressure, Temperature), 1 speed input, internal datalogger, 512kb non volatile internal memory, water/oil temperature sensor, speed and rpm sensor. It supports optional infrared transmitter and receiver. Brand new in the box, never used. $525.00
Magnaflow 2.5" stainless muffler--2.5" inlet/outlet stainless muffler. Brand new, never used. $70.00 SOLD
Full Race Stage 3 GT turbo kit for K-series for dc2/eg chassis. Comes with a custom, one off Full Race equal length T3 manifold (each runner has EGT bungs for individual EGT monitoring), GT35R .82a/r, 2.5" custom stainless steel charge pipes, 3" v-band dp, Tial 44mm wastegate, Tial 50mm BOV PWR/Full Race vertical feed intercooler, Full Race 2.5" hump hoses and t-bolt clamps, custom oil feed and drain lines, custom braided coolant center section feed and return lines. Kit is used for approx. 100-150 miles. All mileage is dyno time and driving to and from a photo shoot. Entire kit is in excellent condition. List is 5449.00. Asking 4400.00 shipped and insured. **Pending sale.
2003 RSX Type S short block. 200 miles on it. Comes with block, main girdle, main girdle botls, crank. The cross hatch hone from Honda is still on the cylinder walls, and crank journals are in absolutely flawless condition. 500.00 **Pending Sale
PWR RSX (all models) dual core aluminum radiator. Used for approx. 50 miles (mostly dyno time and a photo shoot). 350.00
Used Precision 1000cc injectors. These injectors were used on a customer's car for dyno time only. Approx. 30-40 dyno pulls. We maxxed out the 1000cc injectors and went with 1600cc injectors. They are in perfect working condition. 275.00. Sold.
Mickey Thompson ET Streets. 26 x 10.5 x 15. These are bias-ply semi-slicks. Used for 2 passes at the track. In like new condition. There is easily another 50-60 passes left. 175.00 for the pair.
Datalogit Power FC tuning software for Hondas. 275.00.
Extra long road racing short shifter, brand new. The shifter is weighted piece, extra long so that the shifter **** sits right next to the steering wheel. Allows for minimal reach changing gears, very comfortable to shift with. 75.00.
SOLD.
Greddy Profec B Spec II boost controller. Used, but in excellent condition. 225.00.
Full Race Stage 1 GT kit. Used for approx. 2000 miles. Turbo has approx. 500 miles on it. Comes with Full Race T3 prostreet manifold, 40mm Tial wastegate, GT 28RS T3 flanged .82a/r housing, 3" Full Race downpipe, Full Race 8 x 20 x 3 backdoor intercooler, Tial 50mm BOV, all clamps (t-bolt) and couplers (hump hoses), oil feed and return lines, custom braided coolant center section feed and return lines, custom stainless dumptube (which goes completely under the oil pan, and charge pipes. These charge pipes will work in EG/DC/EK chassis and an AIR manifold. If buyer does not have an AIR manifold, we will (for the same price) include a brand new set of charge pipes for your intake manifold and chassis. Other than the charge pipes, this kit will work in the following chassis: EG, EK, DC, EF, or DA. List price on the kit brand new is 4199.00. Selling for 3400.00 shipped.
Custom EG digital guage cluster. Cluster was hand made using SPA digital guages. These are some of the best guages you can buy. Cluster has digital water temp, oil temp, boost, egt, and rpm (tach) guages. All guages are able to have the color changed, have a peak and hold function, and the units of measurement can be changed. All wiring will be left in tact so it's a simple plug and play cluster (still need to hook up ground and power). All sensors for guages are included. This is great for a track car, as it gives you all of your vitals. I have well over 900.00 in the guages alone, plus all of the labor in creating the cluster. 1000.00 shipped. SOLD.
Full Race twin wastegate manifold, (2) 44 mm wastegates, (2) custom, stainless dumptubes extended to go completely underneath the oil pan. 1700.00
Blitz power meter i-d. Used, but in like new condition. Black color option on digital display. Can monitor speed, as well as several auxillory inputs. Great when used with blitz boost controller to do speed based boost control mode. Read more about controller here: http://www.blitz-performance.c...d.htm
175.00 shipped.
Omni-Power Quicklutch Master Cylinder. The Omni-power Quicklutch Master Cylinder has been designed to enable much faster shift times, with greatly improved clutch accuracy & feel. This is accomplished by utilizing a larger diameter piston, which moves the equivalent volume of fluid, with considerably less travel. Brand new, never used. 150.00.
Moates Ostrich. Used for real time emulation with uberdata, crome, hondata, neptune, etc. USB based and super fast in comparision with xtronics romulator. Used for roughly 2-3 hours, in like new condition. 150.00 shipped. SOLD
D-series mild steel head flanges. Great for making custom headers, turbo manifolds, etc. These are water cut, 1/2" thick steel. Had a bunch made for some projects at the shop, and have a bunch extra. 15.00 a piece.
T3 mild steel flanges. Great for making turbo manifolds. 1/2" thick mild steel. 10.00 a piece.
Gt series 3" turbine v-band discharge set-up. Consists of mild steel 3" GT discharge flange, tube side 3" v-band flanged tig'd to flange, 3" v-band clamp and 3" tube side flange to weld to downpipe. New, never used. Whole assembly 75.00.
AEBS Head stud kit for b16a engines. Brand new in the box, never used. 100.00 shipped.
AEBS Main stud kit for b16a engines. Brand new in the box, never used. 90.00 shipped.
Digital EGT gauges. Used for roughly 100 miles. These are compact digital egt gauges that illuminate red EGT value in degrees Farenheight. Includes 1/8 npt threaded body for installation into exhaust, egt sensor, processor and digital display. 125.00 shipped a piece. I have four of these. Great for individual cylinder EGT monitoring.
If you have any questions, please PM me or send an email to info@evans-tuning.com. Prices do not include shipping unless specified.
Modified by boosted hybrid at 1:55 AM 1/7/2006
SOLD.
175.00 shipped.
The car has been in both Honda Tuning and Dsport. In the February issue of Honda Tuning it has the k-series in it and in the December issue of Dsport it has the b-series in it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tommyj »</TD></TR><TR><TD CLASS="quote">ill take those aebs b16 head studs</TD></TR></TABLE>
Sure. Send me a PM and let me know how you'd like to pay.
Thanks!
Thanks!
