help me........
Old Dec 29, 2005 | 04:36 PM
EDVxRICHARD's Avatar
Default help me........
my clutch pedal goes to the ground when i just leave it alone i have to hold it up to go back and then i can push it down change gears and thne i have to hold it up.......try bleedin it you say done that no air come out.....master cylinder replace that bleed it again........still does same ****.....slave cylinder? or any tips to see if my **** is leakin?.......dont see any from wat ive seen and fluid stays topped off hasnt got down one bit
Old Dec 30, 2005 | 03:22 AM
blkhatch92's Avatar
ide go over your owrk, make sure everything is hooked up, even check the pedal . .
Old Dec 30, 2005 | 07:05 AM
idriveadelsol7's Avatar
Default Re: help me........ (EDVxRICHARD)
i believe you're leaking somewhere. that's the only reason for your clutch pedel to fall to the floor unless your master cyclinder has gone. but you said you've changed it
Old Dec 30, 2005 | 11:52 AM
transpar_nt's Avatar
Did you bench bleed the mc before installing it?
Old Dec 30, 2005 | 11:53 AM
Archidictus's Avatar
Unceasing Measure
Default Re: help me........ (transpar_nt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by transpar_nt &raquo;</TD></TR><TR><TD CLASS="quote">Did you bench bleed the mc before installing it?</TD></TR></TABLE>
If his grasp of mechanics is anything approximating his grasp of the English language, I'm going to go ahead and say "no".
Old Dec 30, 2005 | 04:09 PM
Default Re: help me........ (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">If his grasp of mechanics is anything approximating his grasp of the English language, I'm going to go ahead and say "no".</TD></TR></TABLE>
BWAAHHAHAHAHAHAA!!! Maybe he works for the highways department...
VTECdohcter
Oct 30, 2007 04:31 AM
7sins
Aug 24, 2006 11:06 PM
Ryan C
Jun 11, 2004 01:16 PM
feegee
Jan 10, 2004 10:27 AM
T3T495GSR
Aug 18, 2003 01:08 PM
