Question about a B18c1 (p72) GSR head
Old Dec 29, 2005 | 04:07 PM
b18c-ivic_gsR's Avatar
Default Question about a B18c1 (p72) GSR head
Ok i have a 96 gsr engine in my 98 civic hx, i have had it in it about a year and it has always made an odd rattling sound at about 3000 to 4800 rpm until vtec kicks in then it stops and none of my firends hondas do this, a very good mechanic (the guy that did the swap for me JOEY SONGER in forsyth ) said it is possible that its the vtec shims or something like that but anyway my question is since this engine has a few miles on it i was wonder how hard it would be to build this head myself, i like to work on stuff myself and i would like to learn how to rebuild the head since i have recently gotten new rings water pump timing belt bearings head gasket and so on, so far the only thing left is the head it hasnt been touched.
Old Dec 29, 2005 | 04:09 PM
Spracer03's Avatar
Default Re: Question about a B18c1 (p72) GSR head (b18c-ivic_gsR)
im thinking the lma's are worn out
Old Dec 29, 2005 | 04:12 PM
Default Re: Question about a B18c1 (spracer03)
what are lma's?
Old Dec 29, 2005 | 04:15 PM
postman's Avatar
wheres the rattling come from. does it do it on rev or does the car have to going down the road.
Old Dec 29, 2005 | 04:18 PM
Default Re: Question about a B18c1 (postman)
it does it for both but its really loud when you let off the gas around 4000 to 3000 then it just stops the noise OH and it dont do it when the engine is cold only when it gets to vtec operating temp. and yes i have recently had the valves adjusted and that didnt help.
Old Dec 29, 2005 | 04:22 PM
Spracer03's Avatar
lma = lost motion assemblies supposed to keep the vtec rocker arm from rattling when vtec isnt engaged
Old Dec 29, 2005 | 04:23 PM
Default Re: (spracer03)
Oh good call is there any way of checking those with out tearing into the head too deep?
Old Dec 29, 2005 | 04:27 PM
Spracer03's Avatar
i think you could check them just by removing the valve cover... if you push down on the vtec rocker arm (middle) it should feel like there is a spring under it and push it back up
Old Dec 29, 2005 | 04:35 PM
thanx for all the help ill check all that out in the morning when i have so daylight.
jdmgsr1.8
15
May 8, 2011 02:07 PM
Nickbee
Oct 16, 2007 02:40 PM
lv6l
Nov 21, 2004 02:37 PM
newBcrxer
Apr 24, 2004 08:37 PM
civicmandx94
Sep 20, 2003 09:05 PM
