wtf!!! my car is idleing at 1.5k!!!
Old Dec 29, 2005 | 04:06 PM
Spracer03's Avatar
Default wtf!!! my car is idleing at 1.5k!!!
alright so heres the deal i had a couple stock ls b18b's in my garage and a stock gsr head so a assembled me a lil ls/vtec with completely stock parts gsr oil pump, water pump and timing belt and used my new skunk2 intake and throttle body along with my skunk cam gears, anyways long story short ..............
My car is idling at 1500 rpms and if i tap the throttle it'll drop to 800 or so n shoot back up.... already checked tb gasket, im gasket, map sensor o-ring, and tps gasket... timing is dead on... what do you guys think?????????
Old Dec 29, 2005 | 04:11 PM
vietnamese0utlawz's Avatar
distributor placing? my eg does that too..just adjust it..the idle dont worry nothing bad or maybe your engine is cold
Old Dec 29, 2005 | 04:15 PM
Spracer03's Avatar
the idle screw doesnt do crap and im about to adjust the dizzy... i gotta fix it cause gas wastes fast when it never goes below 2k!!
Old Dec 29, 2005 | 04:18 PM
Spracer03's Avatar
anyone else
Old Dec 29, 2005 | 04:21 PM
b18c-ivic_gsR's Avatar
Default Re: (spracer03)
is it ob2 and use 2 o2 sensors if so if both are the same plug i had a problem sorta like that i just had the sensors reversed so i swaped them around and it worked fine.
Old Dec 29, 2005 | 04:24 PM
Spracer03's Avatar
i wish it was that easy... obd1 here
Old Dec 29, 2005 | 04:33 PM
you might wanna check your iacv to make sure the screen isnt cloged
Old Dec 29, 2005 | 08:46 PM
littleredcivic's Avatar
did you over tighten the throttle cable? disconnect the iacv and see what the idle changes to.
Old Dec 29, 2005 | 08:52 PM
JDMlyfestyle's Avatar
Over tightened Throttle cable? Got a hole in a vaccum line? or forgot a vaccum line? Bad Throttle body gasket, Intake manifold gasket,
Hutchinfun
Sep 15, 2017 01:31 PM
rhartman0922
Apr 14, 2011 05:15 PM
DOHC Kid
May 4, 2008 02:43 PM
crxmex
Jan 9, 2006 04:26 PM
PowderB16
Jul 16, 2004 08:34 PM
