how to check tranny fluid levels?
Old Dec 29, 2005 | 01:24 PM
fanta!'s Avatar
Default how to check tranny fluid levels?
how to check tranny fluid levels? and whats the little container in the engine bay, i know ones break fluid and whats the other one?
2000 dx
Old Dec 29, 2005 | 01:26 PM
bostoncal's Avatar
clutch fluid
Old Dec 29, 2005 | 01:34 PM
fanta!'s Avatar
Default Re: (Este_Cara)
so if the clutch fluid is low will it cause problems to the tranny? or make it difficult to do anything?
which is the clutch fluid the bigger or smaller container?
Old Dec 29, 2005 | 01:37 PM
bostoncal's Avatar
clutch fluid resivor is the smaller one. if its low, your clutch pedal will be very soft. sometime is sinks in and hard to come back up.
Old Dec 29, 2005 | 01:41 PM
fanta!'s Avatar
alright so it wouldnt cause problems to my tranny in popping out of gear?
Old Dec 29, 2005 | 01:47 PM
bostoncal's Avatar
Default Re: (fanta!)
no, that would be more of a syncro problem. its its not major yet, go ahead and flush the old tranny fluid out and add about 1.5 quarts of Honda Tranny Fluid and a bottle of Lucas transmission fluid. It works for me for another 8 months or so.
Old Dec 29, 2005 | 01:52 PM
SkoundrelUSA's Avatar
cute little bastard
I don't think you can check your tranny fluid level except by changing it :shurgs:
Old Dec 29, 2005 | 01:58 PM
.Noah Fecks's Avatar
Default Re: (SkoundrelUSA)
so are you wanting to check you tranny fluid? or your clutch fluid?
bennjamin@ozhonda.com's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkoundrelUSA &raquo;</TD></TR><TR><TD CLASS="quote">I don't think you can check your tranny fluid level except by changing it :shurgs:</TD></TR></TABLE>
you can - undo transmission "fill" bolt , and simply put ur finger inside the hole and feel for the "level" - it should be just at the base of the fill hole. If below just top up until it slowly leaks out of the hole.
Old Dec 29, 2005 | 01:59 PM
cute little bastard
Default Re: (bennjamin@ozhonda.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bennjamin@ozhonda.com &raquo;</TD></TR><TR><TD CLASS="quote">
you can - undo transmission "fill" bolt , and simply put ur finger inside the hole and feel for the "level" - it should be just at the base of the fill hole. If below just top up until it slowly leaks out of the hole. </TD></TR></TABLE>
d0h!
Can it be done through the VSS hole too?
Old Dec 29, 2005 | 02:08 PM
nocturnaldragon's Avatar
I dont belive you can check it that way, thats more or a cheater way to fill the thing
Old Dec 30, 2005 | 04:12 AM
Default Re: (nocturnaldragon)
yup the proper way is as i said above - check your manual or online manuals and they mostly tell the same tale. (use a finger via the fill hole)
The VSS is the best way to fill methinks , just be careful retightening those 2 small 8 or 10mm bolts holding the VSS inplace *snap easy*
Old Dec 30, 2005 | 06:59 AM
Ragecloak's Avatar
finger in the fill hole is what i've heard as well
s2kkid
Oct 17, 2005 08:09 PM
mikester_91
Jan 27, 2005 08:44 AM
andrewasf77
Jun 19, 2003 07:32 PM
Chip398193
Oct 23, 2001 01:47 PM
