del sol Aux Lights, is there a switch?
Old Dec 29, 2005 | 12:35 PM
93LSVTecdelSol's Avatar
Default del sol Aux Lights, is there a switch?
Sorry another dumb question, I have the Aux lights not sure if theres supposed to be a switch for them or how i get them operational... they dont turn on when i turn on my headlights, again any help is very much appreciated...
Old Dec 29, 2005 | 12:48 PM
idriveadelsol7's Avatar
Default Re: del sol Aux Lights, is there a switch? (93LSVTecdelSol)
on the gauge cluster/dashboard... look for it. it's a button you can press.
Old Dec 29, 2005 | 01:34 PM
Jedi_Sol's Avatar
Default Re: del sol Aux Lights, is there a switch? (idriveadelsol7)
on the top left of the gauge cluster.... far left.
Old Dec 29, 2005 | 01:42 PM
IHateJDM's Avatar
Default Re: del sol Aux Lights, is there a switch? (Jedi_Sol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jedi_Sol &raquo;</TD></TR><TR><TD CLASS="quote">on the top left of the gauge cluster.... far left.</TD></TR></TABLE>
and they only come on when that switch is pressed and the headlights are on, unless you re-wire them.
Old Dec 30, 2005 | 05:43 PM
dohcVTECeg2's Avatar
Default Re: del sol Aux Lights, is there a switch? (IHateJDM)
OPEN your eyes!
Old Dec 30, 2005 | 07:14 PM
EG2Driver's Avatar
Default Re: del sol Aux Lights, is there a switch? (dohcVTECeg2)
also they ONLY work when the low beams are on
Old Dec 30, 2005 | 08:00 PM
Default Re: del sol Aux Lights, is there a switch? (deadend9009)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deadend9009 &raquo;</TD></TR><TR><TD CLASS="quote">also they ONLY work when the low beams are on</TD></TR></TABLE>
yea they dont work with high beams. you can tap into your wires to set it up with your corners
Old Dec 30, 2005 | 09:23 PM
RARE_EG2's Avatar
^^^^^problems solved
xxliljonxx1
Nov 9, 2015 03:41 PM
mikehawk
Oct 12, 2008 08:31 AM
bdubnyc
May 27, 2008 10:13 AM
roterx7
Mar 28, 2006 02:49 PM
