s2000 injectors on stock civic fuel rail?
Old Dec 29, 2005 | 08:10 AM
EJ8 GSR-T's Avatar
Default s2000 injectors on stock civic fuel rail?
anyone have an idea on how to modify a stock civic fuel rail to work with s2000 injectors? the thing is there (the s2k injectors) like 5-6mm to short...any ideas?
Old Dec 29, 2005 | 12:38 PM
EJ8 GSR-T's Avatar
Default Re: s2000 injectors on stock civic fuel rail? (userdead626)
bump
Old Dec 29, 2005 | 01:26 PM
SkRiBLaH's Avatar
i had to saw off the middle holder, and then file the 2 outer holders (we're talkin on the fuel rail..the type tat looks like a flute) file down about 3-4mm
on the stright billet rail, just remove the spacers and use a couple of washers untill you get the right height.]
pm 4 mo info
Old Jan 20, 2006 | 12:39 PM
racer4life's Avatar
Default Re: s2000 injectors on stock civic fuel rail? (SkRiBLaH)
from what I was told by Rc he said they should fit with no prob they are just smaller in diameter not lenght. but what year you tryin to use them with?
Old Jun 25, 2007 | 04:49 AM
realis9's Avatar
Default Re: s2000 injectors on stock civic fuel rail? (racer4life)
i'm planning on doing this mod soon. Can you guys tell me what you use to shave the fuel rail down?
Old Jun 25, 2007 | 05:37 AM
Libertariat's Avatar
Ek Forever y0!
Default Re: s2000 injectors on stock civic fuel rail? (realis9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by realis9 &raquo;</TD></TR><TR><TD CLASS="quote">i'm planning on doing this mod soon. Can you guys tell me what you use to shave the fuel rail down? </TD></TR></TABLE>
A dremel grinder.
Just to make sure, Do you have mods that require more fuel? (Like more air?)
Old Jun 25, 2007 | 07:40 AM
realis9's Avatar
Default Re: s2000 injectors on stock civic fuel rail? (ek forever guy)
yep
B18c1 JDM p30 .25 pistons
ported type r head skunk IM and type r TB
stage 2 cams
B&M fpr
Will my stock fuel pump be able to handle them?
Old Jan 13, 2014 | 09:12 AM
sell2u's Avatar
I have actually done this. If you have a ob2 manifold where the 2 bolts that hold the fuel rail can be unbolted, you just need 2 of the fuel rail bolts from the s2k, top o-rings from the civic, the bottom o-rings are identical so either one will work. Everything is direct swap and plug & play for OBD2.
Old Jan 13, 2014 | 09:23 AM
Schister66's Avatar
Man U FTW
Old thread back from the dead...didnt notice that at first
locked
Old Jan 13, 2014 | 09:35 AM
doctorake's Avatar
If you loved me, you'd all sell me your magic cards to me today
Veteran: Coast Guard
Community Builder
9 year old thread DOE.
Sprockets
Mar 19, 2016 07:39 AM
wade
Honda S2000
Aug 2, 2012 03:38 PM
K-Spec
Oct 25, 2006 02:28 PM
BLK99VTECR
16
Oct 1, 2005 11:35 PM
S2KSAM
Honda S2000
Dec 11, 2003 04:44 PM
