Parts needed for a B20B swap into 88 Si
Old Dec 29, 2005 | 06:48 AM
JasonH's Avatar
Default Parts needed for a B20B swap into 88 Si
I've looked for several hours trying to find out what parts I'll need to put a B20 into my CRX and came up with nothing really. I'm looking to do the CRVTEC swap and need to figure out what all I'll need to get it done right at the same time instead of dragging it out as I realize what else I'll need to get it done.
So if you know what's needed please give advice.
- Jason
Old Dec 29, 2005 | 07:19 AM
crxnj's Avatar
Default Re: Parts needed for a B20B swap into 88 Si (JasonH)
You gotta figure out first if you want pre obd or obd..And if you want to use a hydro or cable tranny..Then you can get mounts and a linkage just like any other b-series swap..And you'll need a ecu thats good enough for the b20vtec motor..I mean if you run a straight b20 you'll be fine with a stock ls ecu but when you put on the vtec head you're gonna have to find a way to compensate for the extra fuel needed and timing in vtec ..My advice is if you go obd1 is get a chipped p28 with uberdata and tune for the motor..Or if you stay pre obd get a pm6/pr4 ecu chipped with turboedit and 1 wire vtec..
Do some research..
MGates112
Aug 4, 2011 11:01 AM
captain_crunch
Dec 24, 2009 06:51 AM
Xemu
30
Dec 22, 2009 02:01 PM
Kirden
Oct 5, 2007 08:59 AM
eg2oreg6watuwant
Apr 23, 2006 09:49 AM
