Here are some more pics of the damaged cams and pistons
Pistons don't look too bad, just a few contact marks. I'd get the head done with new valves and valve seals then check the compression and do a leak down test. None of the valves broke off right, so there were no metal chunks in with the pistons right?
I shipped the head to JUN today, so they will examine it and let me know their findings. The head was not that bad....the exhaust valves were bent, so they did not sit in the valve seat properly, but they were not bent that badly.
I will rebuild again. I will use JUN cams if they pay for the damage, if not, then I am going skunk2 or Toda......
The Juns have left a bad taste in my mouth
For those who want to see the head, I have posted a large pic here. The pic is huge, so I did not post it on the board
[Modified by canuck-mx6, 2:21 AM 3/19/2002]
I dont know the whole story, but from the looks of it, it seems that :
1. either the head or block was milled way too much resulting in valve to piston contact
2. the exhaust cam slipped or was adjusted way too far
3. Mishift at high rpms
But from the pics I am not surprised the cam broke as the valves hit the pistons really hard and something had to give. Usually its the valves that go though. Got any pics of the valves?
Of the miles you have on the cams, How many miles was actually in VTEC. I suspect that the cam was installed off and it ran okay on the low lobes, than when the high lobes(long duration) kicked in, WHAM. broken parts.
Keep us posted on the outcome because I am very interested in what JUN will say is the cause of broken cam.
nah if they hit the vales would have bent way before the cam broke.
hey where did you get these cams? is it in Toronto?
Also who was trying to tune your car while you were at the dyno?
