sway bar help please
Has anyone used Omni Power LCA's and installed a GSR sway bar with it? If so, what end links did you use. This is the only thing keeping me from installing the sway bar. I just don't know where to find the correct end links. This sway bar is a stock GSR bar with the swivel ends still on it. This post is not a "what should I buy", post, and I did search this topic.
The Omni LCA don't change a thing when it comes to rear sway bar install. Use the same end-links you would if it were your stock LCA, so civic SI and GSR (i believe) end-lniks will work. Also, ASR or Function 7 helm joint end-links will work, ASR is $70 but a bolt on the end (so easy to torque) where as Function 7 is a hex nut but only $40.
GSR is 14mm and requires no subframe reinforcement as the Civic SI and Acura 1.6EL come with stock subframes same as Civic CX but have a 13mm sway bar from the factory. 19mm+ needs reinforcing, but i also say why 14mm, 19 would be better to do it once. Yes 14 will be a drastic improvement over 0, but 19 or 22 is a great improvement from 14.
