Climate control fans not working??? help...
When i got in my car and i put the fans on to get heat on the inside the fans do not come on...
Now i tried to check a few fuses but came up with nothing...
Has anyone had this problem?
Anyone know a fix or a way to check the whole unit?
Thanks!
Thanks!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95integraLS003 »</TD></TR><TR><TD CLASS="quote">When i got in my car and i put the fans on to get heat on the inside the fans do not come on...
Thanks!</TD></TR></TABLE>
sounds like the blower motor is inoperable.
assuming you have a test light, you can attempt to diagnose motor. a voltmeter would also work too. if you have these i can walk you through the steps according to my OEM repair manual.
finally found on page 1064.. if i remember correctly, it talks about a heater blower fan which im figuring is the fuse for the motor... Its a 40A fuse.. hopefully i can pick one up tomorrow and test it out to make sure its the right one... I just need to get this fixed because of the big issues hondas have with the windows fogging up... these fans are essential!!!
If anyone knows anything about an issue like this, any info would be great!
Thanks
Thanks
unstopabledj
Sep 19, 2004 08:04 PM
