Del Sol didn't pass emissions
Old Dec 28, 2005 | 06:25 PM
B18Redline's Avatar
Default Del Sol didn't pass emissions
I just got a Del Sol and it didn't pass emissions. I'm thinking it could possibly be the o2 sensor. Anyone have any ideas on what it may be?
Thanks!
Old Dec 28, 2005 | 06:41 PM
oo3's Avatar
oo3
Default Re: Del Sol didn't pass emissions (B18Redline)
i'm not sure what kind of tests they run for emissions in your state, but which one did you fail?
Old Dec 28, 2005 | 07:17 PM
littleredcivic's Avatar
show me the numbers and what mods you have.
Old Dec 30, 2005 | 05:44 PM
dohcVTECeg2's Avatar
Default Re: (littleredcivic)
be a lil more specific and i can help
Old Dec 30, 2005 | 09:23 PM
postman's Avatar
mainly what mods do you have and what is your five gas
Old Jan 3, 2006 | 02:18 PM
B18Redline's Avatar
Default Re: Del Sol didn't pass emissions (postman)
hc ppm 15mph
limit 183
mine 143
hc ppm 25mph
limit 200
mine 154
co% 15mph i failed the tests at the 15mph and 25mph marks
limit 0.73
mine 1.92
co% 25mph
limit 1.07
mine 2.00
no ppm 15mph
limit 2400
mine 2160
no ppm 25mph
limit 2333
mine 2123
the reason i put the exhaust on was because, the car had the full muffler assemble rusted underneath including the hders
so i just bought http://cgi.ebay.com/ws/eBayISA...WN:IT
and
and i got a midpipe as well from a local place
Old Jan 3, 2006 | 08:42 PM
the gay *** "jdm" high flow cat is most likely the problem. its not jdm. if you ever see a jdm cat, you better have paid about 800 for it.
Old Jan 3, 2006 | 09:03 PM
civic_in_LA's Avatar
definetly sounds like your Cat. I had the same BS problem on my civic, failed the same test, replaced the CAT and I passed.
Old Jan 4, 2006 | 08:18 AM
B18Redline's Avatar
Default Re: (civic_in_LA)
Thanks guys for your help.
Do you think a factory integra cat will fit right?
Old Jan 4, 2006 | 08:52 AM
maka's Avatar
Default Re: (B18Redline)
heard a rumor also, if you use higher octane gas, it will burn cleaner. and yeah, the cat will make a big difference,
i had a smog done, and my max pts i was allowed was 180 something, i was hitting 2300 pts, woww.. changed my cat and i was at 20something pts.. change that cat.
Old Jan 4, 2006 | 04:43 PM
Default Re: (maka)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maka &raquo;</TD></TR><TR><TD CLASS="quote">heard a rumor also, if you use higher octane gas, it will burn cleaner. and yeah, the cat will make a big difference,
running a higher octane gas than required by the engine will not burn cleaner. in fact, it may have higher HC numbers because an optimal engine will perform best when it has the octane closest to its detonation threshold. with a higher octane gas, you will possibly have unspent gas and make HC numbers worse.
HairyHarry
37
May 3, 2016 06:16 PM
MUGEN_EG95
Nov 8, 2009 03:17 PM
dippy
Nov 1, 2008 12:52 AM
B18Redline
Mar 17, 2006 09:48 AM
Mentat Ghola
14
Feb 7, 2004 12:15 PM
